abbott Posted November 1, 2012 Report Share Posted November 1, 2012 hey all, havent posted in a while but got a question! i have a ke25 that appears to not be selling or barely have any interest! now I'm thinking of getting a couple of panels resprayed if i keep it so also thinking maybe its time to get some te27 about it! my issue is that i want to put on te27 flares BUT i don't want to damage the standard guards in case i get defected and seeing as I'm not going to run it super low i don't see this being an issue clearance wise! now having never had flares to look at in real life does anyone thing there would be a way to mount the without bolts, maybe an adhesive? may seem like a dumb question but thought id ask 1 Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted November 1, 2012 Report Share Posted November 1, 2012 Sikaflex or strong double sided tape. Both will probably ruin your paint on removal though. Quote Link to comment Share on other sites More sharing options...
19914afc Posted November 2, 2012 Report Share Posted November 2, 2012 Sikaflex but wouldn't use double sided tape to hold flares on. My rear flares I cut the original rear flare off, welded the old inner guard to where the outer guard was and then used roofing self drilling screws because they have the rubber washer on them. Then for the fronts just cut off the old wheel arch and nut and bolt, although that's on a T18 and probably completely different to a ke20 haha. Quote Link to comment Share on other sites More sharing options...
Jono.C Posted November 2, 2012 Report Share Posted November 2, 2012 (edited) I'd look at maybe even doing it with magnets/ magnetic strips some how? (Also Sikaflex would pull the paint right off when you removed the flare) Edited November 2, 2012 by Jono.C Quote Link to comment Share on other sites More sharing options...
parrot Posted November 2, 2012 Report Share Posted November 2, 2012 Seeing as though the guards you use will be fibreglass, you either sikaflex or bolt them on. The guard profile is slightly different from TE27 to KE25 but not insurmountable. If I get keen, I'll try and post up some pics showing the differences between the two. My KE25 is not ideally situated at present for side on photos Quote Link to comment Share on other sites More sharing options...
troyota Posted November 3, 2012 Report Share Posted November 3, 2012 I have used a special tape for this previously without a drama. In the event you wanted to remove them , simply apply prepsall or glue removers and off the come with no paint issues. You must make sure the surface is well cleaned before though. Pm me if you want either the tape or a fast dry MSP Urathane adhesive . Quote Link to comment Share on other sites More sharing options...
philbey Posted November 6, 2012 Report Share Posted November 6, 2012 Yeh I'm voting tape. Not the bunnings crap though, you want some good 3M high bond tape, they've grange assize range and when applied properly the stuff is tough as. You can get some really thin stuff as well. Sikaflex will be messy and nasty. Quote Link to comment Share on other sites More sharing options...
troyota Posted November 7, 2012 Report Share Posted November 7, 2012 All the good tapes are clear in colour and are VHB (very high bond) . I have people using this tape for mounting gps sensors on the outside of earthmoving equipment etc. This shows that the tape will perform well exposed to the elements. 12mm & 18mm sizes are the most popular. Quote Link to comment Share on other sites More sharing options...
RA28GT Posted November 7, 2012 Report Share Posted November 7, 2012 Wurth do a power mount tape that will hold them no problems at all. I can't imagine the paint would love it however. It might be ok with some proper adhesive remover. But at the end of the day the guards really are designed to be cut, you could see the original guard inside the flare if you don't. 1 Quote Link to comment Share on other sites More sharing options...
abbott Posted November 8, 2012 Author Report Share Posted November 8, 2012 thanks heaps for the replies guys, really have to sit down and think if I stick with selling or starting spending money on her! Quote Link to comment Share on other sites More sharing options...
