What KE? There's more than one. What application are the springs for? Lowering, performance, stock replacement? If you don't want to get flamed be more specific when you ask a question.
Measure up the old ones and take your tape measure to pinch a part and hunt away. For example, cut down HZ Kingswood springs will fit onto KE20 struts.
Don't you have a grinder??
How low do you want it? Take a coil off, lose an inch an put the rate from 100lb/in up to 120.
2 coils means about 40mm off ride height and a rate of 150lb/in.
Go silly and it won't remain captive under droop, but will pound your back before then.
Cable ties fix this though ;)
