Bring Da Ruckus..! Now A Metruck..!
first thing was to swap over front rim/tyre/brake assembly
from this
10" x 2.125" with a crappo tyre
to this:
10" x 3" new 90/90/10 road tyre that came with my orders for the Ruckus(never bolted it on her tho)
Edited by nerfbat
  • Replies 173
  • Views 420.8k
  • agreed mate they are stickers and will be removed, as soon as i get it running right   no idea mate. on long rides, i may feel a bit hunched over. will have to wait til i take her for a good ride(
started the strip down of the rear
pretty much where i got to, ran out of light
oh put the speedo in the battery box and tidied up the Bars on the ruckus, too
will take a better shot of the setup when i can
some idea as to what my plan is
ruck rear, met front like this, looks the secks
Edited by nerfbat
didnt have to work today so i got stuck into it
Met front with a Ruck rear = Metruck
or the OZ version,
Scoopy front with a Zoomer rear
shall we call it a Scoomer or a Zoopy?
lol
comparison pic of the Met(Right) vs Ruck(Left swingarm
swapping them gives you a nice stretch(Ruck into a Met) or shorter wheelbase(Met into a Ruck), depending on which way you go
the weights in the variator seem fine
all bolted together.
got the whole Ruck rear end fitted up, minus the Mojo Customs fatty/extension kit
how the ruck front end sits for now...
ran out of light to do anymore
fingers crossed, this should be running tomorrow
then to get the Rucktro together
:-P
thanks for your time
got her running ok, tidied up the wring a bit, still needs more
havent wired up the tail light yet
the blue bag holds the battery, as the battery and ecu are usually in the big box under the seat on a std Met/Scoopy
can't afford to buy anything for a while, but i need paint for her, wire the tail light, and fit the big gun exhaust
wont be fitting the fatty or extra stretch kit til i test it out for a week or so, iron out the bugs, etc
So does it just stay registered as a Zoomer? Because its "mostly" Zoomer
Edited by It's_AUDM_Yo
hi mate, i assume i can as i have kept the frame part with all the Zoomer 'VIN' etc.
once this girl is running right and i am reasonably happy with her, i will start on the Ruckus/Zoomer build
Thanks to Trev(who gave me a huge workbench) and rob who helped bring her over, i now have plenty of space in my shed to 'Bring Da Ruckus..!
tail light wired up, and took her for a short ride around the block to test her out
seems ok, but i will need to play with the carby i reckon, rejetting, etc, after removing the big and restrictive air box, and putting the 'Big gun' exhaust on her
playing with jets today.. got her running rather nicely
pulls hard up to 60 now, but then sits on the rev limiter at around 70(speedo ends at 60, guessing 70 due to the needle place past the mark), but at least its perfect for town riding
if i get her pulling hard and smooth right through to 65ish, i will then play with the variator/ weights/ ramps and push it a bit
i am noticing a slight hesitation around 35-45 kms, but i found an easy way to space the needle up a bit, enrichening the mixture throughout the rev range
tomorrow, ima try it, and play with the jets more
more pics too
then to paint it all either OD green, or flat back when i can afford it
and THEN.... back onto the Ruckus/Zoomer
Edited by nerfbat
pulled the carby down, put an M25 washer under the needle to increase fuel flow, also put in a bigger jet from the other carb, it now pulls hard up to 60 kms
i didnt take pics of the carb trick, but i found some from the guide i used
before
washer placed on needle
and after
it essentially enriches the mix thrughout the throttle range
will check the plug after a day or so riding and adjust to suit
tomorrow the Big Gun exhaust gets fitted properly, which may require a retune of the carb
but I can't wait..!
then paint, and i'll be sorta happy
mate..! thats pure awesomesauce..!
don't tempt, me lol
but also, thanks for the pics..! that is pretty much exactly, the colour scheme i am looking for
cheers mate
hey guys, check this out
http://www.houseofja...gkok-motor-show
concept show reveal a Cali style Zoomer they may be bringing out..!
if so, i am excite..!
GOT FAT?!?
Edited by nerfbat
couldnt afford paint, so i decided to do it on the cheap with the left over SCA Matt Black paint cans i had, also thanks to Rob for giving me one, doubling my stockpile..lol
these, plus the leg guard panel, are the pieces that got the Wet & Dry treatment
after the first 2 coats
decided i needed to buy more paint after using up the 2 cans i had
sold some of my old games to my mate's cash shop and bought 4 more tins of paint for 10 bucks
so, the paint job cost at most 15 bucks... and I'm sure it will show when i bolt her all together tomorrow arvo
last thing i did was fit a red T10 LED to the cluster, another leftover from the black KE 36 panno
will post more pics tonce i get her back together
