Big Port Searching
It's always had a high idle at 2100rpm with the idle screw all the way in n it has just started searching every now n then can anyone tell me what I need to do its in an ae71
Don't know how il do a search
vacuum leak.
If you haven't already blocked off the idle-up system on the throttle body then scroll through this to find out how:
http://www.rollaclub.com/board/topic/56218-rians-ke70/page__st__360__p__644229
If you have already blocked off the idle-up system then you should pull your inlet manifold off and check your gaskets.
Edited by rian
vacuum leak.
http://www.rollaclub..._360__p__644229
I forgot to ask this on your thread but how come you removed your cold start thingo? Although by the looks of that it literally just lets more air in
Smallports just have an extra injector for cold starts.
^The idle-up/cold start thing is operated by the coolant temp and it was too much effort to run the coolant lines to the throttle body. The metal coolant lines need to be shortened when you put the 4A in RWD format, and when you shorten them you lose the pipes that take coolant to the throttle body. Doesn't matter, still starts on cold morning so it's all good.
Edited by rian
Yeah, smallports have a way different system. Its not ever "cold" in Australia as far as cars are concerned.
Smallports have the same style wax-pellet cold-idle valve and Cold Start Injector setup as the bigports do (at least in FWD-land)
Spoken like a true Northern State Resident :P
