more cutting and welding
first cutting
new plate
also fitted in a hell of a lot of plates here...
also made a little thingy for the "Rally Rolla"
another shot, keep in mind that its not finished and the front end is very stripped, no grill, no nothing :)
haha, nah, since I'm fixing it i feel like i have the authority to brake it again :P no, but its not going to be used in competition, its going to be a road legal car for daily use :) but still a rally car for fun on gravel roads and for the looks :)
is there anyone here with any experience with cutting the springs on a ke20?
or what do i need for a coilover convertion, i have no experience with suspention, but nothings too hard :) i just need someone to tell me what i need .. :)
Edited by SM Hunter
The best way would be to upgrade your front struts, run AE86 gear. Then you get a brake upgrade too. Plenty of places sell coilover kits to fit to the struts, there are ones to suit ke20. You could buy ready made ae86 ones and put them in but youd need ae86 steering arms too.
ill have to think about that after i get it road legal, for now iv cut the springs 1 round, its not low enough yet tho... but i want to know how it handles before i spend some big money, I'm still studying so I'm not very rich... I'm rather poor..
but iv instaled the new bearings and then i could not get the brake caliper on and got a bit mad and threw one of the brake pads on the floor and it cracked.. soo iv bought new ones for 17 bucks included shipping from Down under :)
here is a pic of how how its sitting now :)
need to get it somewhat assebled to take a pic soon :)
almost finished welding on the right side, finished in the front only missing the back end and the left side :D
keep in mind I'm only 16 and have next to nothing welding experience, this is my first CAR project... iv toadaly restored an 1963 Honda super cub last year and painted it myself, and that turned out pretty good,
toadaly love it, done it ALL myself.. the engien is an Lifan 125 , got the original engine running but it was to weak for my intention... by laws mopeds are only allowed to go 45 km/h .. but iv gotten this baby up to 97km/h :D
a little video of the moped :)
anyways orderd some turnbuckles to brighten up the front end and make the Catkiller stiffer
iv also orderd some other stuff, will wait untill it comes to reveal :)
Edited by SM Hunter
heyo, yesterday i found a 5R 2.0 Toyota Crown engine from 1969 that i thought i woud try to fit in the corolla :)
found out i needed some new parts here and there..
took the carb of this thing
gearbox of this
starter and distributor of this
and today if was ready for a pallet fire.. :D
fired stright up :D got a video on my facebook page , its in my signature
then i stared to take out the 1,2 of the corolla
20131026_185031_zps03238912.jpg20131026_183120_zpsf36b263a.jpg20131026_183120_zpsf36b263a.jpg
hmmm.. wonder if the gearbox etc is gona fit and mount up to the driveshaft ...O.o
this is how far i got the 2 liter down into the rolla
at this point a part of the gearbox is tuching the gearboxtunnel... it needs to be wider :)
but i think the gearbox of the 5R is longer so the engine will be much more further ahead... any ideas? shortening the axel between the gearbox and the diff?
and i got a problem with the engine mounts :)
this will be fun :D I'm excited :D
i got it to fit :D
had to remove the exhaust and chop some of the gearbox tunnel and then it was all good, only need to move the engine mount and shorten the axle
also had to remove the fan, going to install a electric fan on the other side of the radiator :)
oil filter was in the middle of the engine mount...
made 2 plates, one to bolt to the filter and one to the block , then I'm gonna run 10an oil hoses betwwen them :)
made new engine mounts
found some parts
this does not fit in the corolla diff.... its from a crown, ( similar car as the engine is off)
the manifold had cracked , needed a new one...
found 2 "new" manifolds
fitted the orginal corolla dynamo
the engine fell down from the stand... broken oil pan, or more crushed than broken
found a new oil pan, these should be similar...
made something to convert the clutch to wire... kind of difficult, due to the arm going the opposite way of the corolla :P
installed a shifter, and i LOVE it!
today i shortened the tail shaft and made a adopter from crolla diff to crown tail shaft..
sawing the tailshaft
cut off 20 cm and welded it together again
tomorow I'm hoping to start on the exhaust :D
still waiting for my oil hoses to arrive so i can start the engine :D
Wow your making good progress, good to see someone who can stay positive when you get to tough parts.
That shifter looks pretty cool! Haha
I love the builds of people that are willing to jump in there and do some DIY stuff. That engine sounds great idling on the pallet. Looks like it will be fun fitting it in place.
thanks :D
done some more :D
conected up all the cooling
also done all theimportant wires , just need to turn the key to start it
converted the carb to wire, used to thin plates so it bends, needs to do this again...
oil lines arried.. but they where to big... so ill go for plan B :)
started welding a bit more today
painted the areas where i had sanded or welded , so it was bare metal, white...
all finished here
onyl missing the plates behind the rear wheel and the front fender..
exited to start on this one :D
