oopsiy Posted September 6, 2013 Report Share Posted September 6, 2013 Hey guys. I was thinking about getting the ke25 fender mirrors off eBay, and was wondering if anyone would know the exact measurments to drill the holes ? Thanks heaps guys ! http://item.mobileweb.ebay.com.au/viewitem?sbk=1&nav=SEARCH&itemId=310738537784 Quote Link to comment Share on other sites More sharing options...
parrot Posted September 6, 2013 Report Share Posted September 6, 2013 I have some TE27 guards here, I'll measure them up Quote Link to comment Share on other sites More sharing options...
mattress Posted September 6, 2013 Report Share Posted September 6, 2013 I've wondered this for a KE10 myself... Quote Link to comment Share on other sites More sharing options...
oopsiy Posted September 6, 2013 Author Report Share Posted September 6, 2013 sweet dude thanks alot! Quote Link to comment Share on other sites More sharing options...
parrot Posted September 6, 2013 Report Share Posted September 6, 2013 (edited) OK, bear with me here. The distance between the front 9mm diameter hole and the rear 6mm hole is 40mm centre to centre The front hole is 55mm from the inner edge of the guard to centre hole(i.e. the edge that sits next to the bonnet when closed) The rear hole is 56mm from the inner edge of the guard to centre hole. For placement of the front 9mm hole do as follows. Looking at the bolt holes that mount the guard to the body. The distance between the second mounting hole from the front to the third mounting hole is 185mm centre to centre. If you measure back 95 mm from the second (front) hole, and draw a 90 degree line with pencil, that is the location of the centre of the front hole. EDIT: Make sure you measure twice and drill once, ONLY after you satisfy yourself the placement of holes tallies with the photo's! No responsibility taken etc Edited September 6, 2013 by parrot Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted September 6, 2013 Report Share Posted September 6, 2013 Like this? Quote Link to comment Share on other sites More sharing options...
parrot Posted September 6, 2013 Report Share Posted September 6, 2013 Exactly. I'm such a techno retard..... Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted September 6, 2013 Report Share Posted September 6, 2013 Ha, all good its just MS Paint. I'll send you an invoice. Quote Link to comment Share on other sites More sharing options...
RA28GT Posted September 6, 2013 Report Share Posted September 6, 2013 There should be a 'notch' under the guard that the spring cup sits in perfectly. All my early Toyota's have it. That's the exact position for original style fender mirrors. Quote Link to comment Share on other sites More sharing options...
oopsiy Posted September 6, 2013 Author Report Share Posted September 6, 2013 Thanks heaps parrot and b.l.z bub. Appreciate it ! Let you guys know how I go.... Ill have a look and see if I can see anything ra28gt. Thanks again !!! Quote Link to comment Share on other sites More sharing options...
wagn Posted September 6, 2013 Report Share Posted September 6, 2013 Mine has the holes from factory the inside of the guard has some sort of tar patch or something on the inside and then filled over with bog take your guard off and have a look the holes might be there before you go drilling Quote Link to comment Share on other sites More sharing options...
parrot Posted September 7, 2013 Report Share Posted September 7, 2013 I've got 3 te27 and two ke25 guards, all later style levin type. The te27 guards are obviously drilled, whereas the ke25's aren't. None of them have anything inside the guard Quote Link to comment Share on other sites More sharing options...
