So a small up date on the car, cut the part were the pro shaft literally was touching the car due to lowering a lot the car and made a new panel little higher that the original so that it does not touch the car. Really happy how it turned out. Next step is to grind the access welding hammer the panel from underneath and and add a new panel to cover the differential bell housing.
Transmision i.e t50 fitted perfect fit without any cutting or hammering. It was made to fit it. I was told that a certain type of t50 but does not fit due to different confing i think from the starter.
Edited by novaluke
