March 16, 200620 yr comment_107234 banjo diff (live axle assembly) - ke20, ke25, ke30 front loading, easy changing, width of housing varies between models 1320mm ke20/25 , 1370mm ke30 diff centre 5.7, 6 inch interchangable centres borg warner diff (live axle assembly) - ke35, ke55, ke70 rear loading, harder to change, length varies between models ??? mm ke35, ???mm ke55, ???mm ke70, mount types vary (coil, leaf) diff centre 6, 6.38inch now the question! can the borg warner centre out a ke70 - 6.38inch fit into a ke35 / ke55 housing? Report
March 17, 200620 yr comment_107387 not an answer to your question but what about the banjo diffs found in some ke70s? sorry to throw another question but i wonder if it will help... Report
March 19, 200620 yr Author comment_107561 someone must know about the ke borg warners! will the 6.38 inch centre out a ke70 borg warner fit a 6.0 inch ke55/ke35 borg warner? :D Report
March 19, 200620 yr comment_107617 Only one way to find out... Someone less lazy than me needs to try it ;). Once they've done that let us know if I can do it too :D. Report
March 19, 200620 yr comment_107625 How many times does 6.38 go into 6.0? Theoretically, maths states that it wont go into it. Only one way to find out though....:D Edited March 19, 200620 yr by AE35 Report
March 29, 200620 yr Author comment_109048 hmmm this is what I'm looking for! may have to email the guy ke30 with ke70 diff centre Report
March 29, 200620 yr comment_109131 don't forget about the axles??? are they the same o.d and are they the same style spline. I know my ke35 ones are smaller then my mate ke70 ones. just a thought! Report
