altezzaclub Posted December 28, 2013 Report Posted December 28, 2013 I haven't replaced the condenser yet it the dizzy I'll go to the shops now and get a new one How's that coming along? Make sure the power going into the dizzy is insulated as it goes through the side. If the clips or wires touch the dizzy body they will short out the power straight to earth. Check it with the multimeter. With the points open and the coil -ve wire in your hand you should get an infinite ohms reading, or certainly a very high one. If you turn the motor with a spanner to #1cyl TDC the multimeter will tell you exactly when the points close, and that will give you the ignition timing off the crank pulley. Should be 8-12deg, book says 8 I use a few more. Put a tiny spot of grease on the cam in the dizzy so it lubricates your new point's rubbing block, otherwise they wear away quickly and the points close up. Quote
altezzaclub Posted December 28, 2013 Report Posted December 28, 2013 ...and I forgot to ask- is that new coil a low voltage or a 12V. Most coils are designed to run without a ballast resistor, so they need 12V all the time. The ballast resistor won't feed them enough to perform properly. The low voltage coils are designed to run at peak efficiency on 6 or 9 volts. So long as the guy in the spares shop knew what he was doing. Quote
Pawlyke70 Posted December 28, 2013 Author Report Posted December 28, 2013 Haven't check the timing so I'll get on that Quote
Milkman Posted April 18, 2019 Report Posted April 18, 2019 I can't start my ke70 CSX 4k 1984 plx help and what is it missing?. , Quote
