I Got A Ae82
i just picked myself up a 1986 AE82 CS corolla hatchie and I'm researching about a engine for it, the one in there has a bit of zip however i bet my mate i could beat his magna which pushes out 170kw, so its on :) ive looked at the 4AGZE with its supercharger and i was wondering how hard it would be to get one in there. or better yet is there a faster one to chuck in? any help is appreciated.
A mate of mine did the AE82 4agze thing, DAMN THAT CAR WAS COOL!
it would be best to get a 4agze front cut so u can also use the front brakes and what ever (no point going faster if u can't stop!)
  • 2 months later...
so the 4agze is the way to go, how much would a front cut and conversion cost? or would it be cheaper to just buy a 4agze rolla?
using a front cut and replacing all belts, tensioners, water pump, new clutch, rear disc's, efi fuel lines, efi tank, associated wiring and odd and ends that will be needed ie oils and coolant. i would say be round the $6000 - $7000(including price of cut)thats if u do all the work ur self
or then there the option of buying a converted corolla for bout the same price.
the down side of both options is that u never know what the engine has been treated like before u get it.
but another down side for the cuts is that it getting harder to find low km cuts (not that they don't exist just harder to find)
mind u the price i said is just an estimation from a few guys that have performed a few of these conversions.
anyways mate goodluck with ur decision either way :)
Edited by MYSTIK
  • 1 year later...
Hey mate,
You would be wise to have a look at the NA options.
I have just finished a conversion from a 16v to a silvertop 20v in my AE82.
Man it hauls ass. Incl.
Silvertop with VVT
272Deg cams with a larger lift
2 lt surge tank
550 hp bosch fuel pump
heavy duty clutch
cold air intake with the AFM sensor inputs.
4in21 exuast manifold with the same sixe pipe all the way through (2 and a 1/2)
It SMOKES my mates Turbo Suzuki Baleno that has made a 168 fwkw and a high 13 sec pass. and he is nothing but light in the revision mirror.
Please understand that the Baleno is at least 50-100 kilos lighter, and the AE82 is not tuned and has not been dyno-d.
Have a look at
www.tweakit.com.au serious potential.
