January 27, 201412 yr comment_676330 I'm gonna reuse this gasket do i need to put anything on this to make it seal or i can just put it on dry like this? also any carb help or advice is appreciated :D Report
January 27, 201412 yr comment_676339 I've re-used them dry, or often put a smear of grease on each side. Too complicated to put a sealant on, you don't want silicon sticking in those holes. Report
January 27, 201412 yr comment_676340 You want to make sure both surfaces are perfectly flat though. ie get a razor blade and spend some time on both surfaces. Report
January 27, 201412 yr comment_676342 Too complicated to put a sealant on, you don't want silicon sticking in those holes. I'll vouch for this, tried it once, silicone has a knack for finding the exact hole to get stuck in to give you grief! Report
January 28, 201412 yr Author comment_676369 didnt plan on using silicone but will try the grease thing thanks. when i opened it up a few days ago the gasoline in the bowl had orange crud in it could it be gas or rust from the tank? Report
January 28, 201412 yr comment_676376 Old deteriorated petrol most likely. Go very light on the grease. Report
January 28, 201412 yr Author comment_676423 yea i left the fuel there around fall. do i need to flush it out? thanks Report
January 29, 201412 yr comment_676461 Can you dilute it well with fresh fuel? The best part of the petrol does evaporate over 6months and the heavier fraction left behind does not fire as well. Report
January 29, 201412 yr comment_676462 Always a good idea for good fuel when doing engine work. ;) Report
January 29, 201412 yr Author comment_676523 did put good fuel in it since i got it 91 octane. highest possible octane here in canada lol. @altezza dude dillute the whole tank or carb itself? Report
January 30, 201412 yr comment_676581 clean the carb bowl with brake cleaner and fill the bowl up with that when reassembling. best change the fuel filters while you're at it Report
