February 21, 201412 yr comment_678091 I will be swapping this: into this: I will document each step as I go along. The firewall has been notched 4" and the section has been boxed: The original shifter has also been relocated to suit the R154 The car is plauged with a little rust so progress will be slow. Before: After: Plans include: rear-mounted radiator 3" SS exhaust 8.8 rear 4 link T70 turbo 30 x 12 x 3 I/C mounted behind grill expansion tank modified oilpan custom catch can shaved bay bigger injectors (not decided which yet) aftermarket ecu (not decided which yet) fuel cell ans external F/P swirl pot All welding and fabrication will be done by me. My inspiration for this was this little bugger: Just a little update! Installed the motor to check clearances and to lock up the I/C Cut out the spare tire tub an surrounding sheet metal: Added 1"X2"X1/16" square tubing for reinforcements and radiator mount. Combined a generic catch can and expansion tank to make this unit: Edited February 21, 201412 yr by SpicemanSteve Report
February 21, 201412 yr comment_678094 Why a 7M and not a 2J? Surely it would be the same amount of work? Or just working with what you have? Should be a beast either way. You Yanks can do fun stuff to your cars, like this 1UZ-fe supercharged KE35. http://www.speedhunters.com/2012/07/barely_lega/ Over here is Aussie we put fluffy dice hanging from the rear view mirror and we are put in prison for life. Edited February 21, 201412 yr by B.L.Z.BUB Report
February 22, 201412 yr comment_678142 Fluffy dice could put an eye out if you go around a corner too rapidly. Report
February 22, 201412 yr comment_678148 We're not allowed to go around corners now. We have to stop on turnstiles, rotate the car then keep going. Report
February 22, 201412 yr comment_678158 This is so legit; overcome all head loss! Edited February 22, 201412 yr by rian Report
February 23, 201412 yr comment_678204 Love your work, nice work on the tunnel, should be fun when done. Good goin. Report
February 24, 201412 yr Author comment_678279 Why a 7M and not a 2J? Surely it would be the same amount of work? Or just working with what you have? Should be a beast either way. You Yanks can do fun stuff to your cars, like this 1UZ-fe supercharged KE35. http://www.speedhunt...07/barely_lega/ Over here is Aussie we put fluffy dice hanging from the rear view mirror and we are put in prison for life. Working with what the customer had...........I saw the build of this car on his site @ cardomain. Love your work, nice work on the tunnel, should be fun when done. Good goin. Thanks Report
February 24, 201412 yr Author comment_678280 This is so legit; overcome all head loss! Thanks bro. I had to modify this side extensively. The outlet was inline with I/C. Report
May 24, 201412 yr Author comment_683201 UPDATE The rust repair has gone well and completed: Wiring at the start: Completed this way: ECU and engine electronics in passenger compartment: Intercooler hotside piping done: Downpipe done sometime ago: Wilwood pedals and masters: Small teaser: http://s83.photobucket.com/user/strfabwerkes/media/Pic1053.mp4.html Report
July 5, 201412 yr comment_685214 Hey mate nice work what engine mounts did you use? Custom? Or off another car Report
