7M-Gte Into 1976 Te37
SpicemanSteve
I will be swapping this:
into this:
I will document each step as I go along. The firewall has been notched 4" and the section has been boxed:
The original shifter has also been relocated to suit the R154
The car is plauged with a little rust so progress will be slow.
Before:
After:
Plans include:
rear-mounted radiator
3" SS exhaust
8.8 rear
4 link
T70 turbo
30 x 12 x 3 I/C mounted behind grill
expansion tank
modified oilpan
custom catch can
shaved bay
bigger injectors (not decided which yet)
aftermarket ecu (not decided which yet)
fuel cell ans external F/P
swirl pot
All welding and fabrication will be done by me.
My inspiration for this was this little bugger:
Just a little update! Installed the motor to check clearances and to lock up the I/C
Cut out the spare tire tub an surrounding sheet metal:
Added 1"X2"X1/16" square tubing for reinforcements and radiator mount.
Combined a generic catch can and expansion tank to make this unit:
Edited by SpicemanSteve
  • Upvote 1
Why a 7M and not a 2J? Surely it would be the same amount of work? Or just working with what you have?
Should be a beast either way. You Yanks can do fun stuff to your cars, like this 1UZ-fe supercharged KE35.
http://www.speedhunters.com/2012/07/barely_lega/
Over here is Aussie we put fluffy dice hanging from the rear view mirror and we are put in prison for life.
Edited by B.L.Z.BUB
http://www.speedhunt...07/barely_lega/
Working with what the customer had...........I saw the build of this car on his site @ cardomain.
Love your work, nice work on the tunnel, should be fun when done. Good goin.
Thanks
  • 2 months later...
UPDATE
The rust repair has gone well and completed:
Wiring at the start:
Completed this way:
ECU and engine electronics in passenger compartment:
Intercooler hotside piping done:
Downpipe done sometime ago:
Wilwood pedals and masters:
Small teaser:
http://s83.photobucket.com/user/strfabwerkes/media/Pic1053.mp4.html
