4Agze Cel Comes On, But No Codes.
B.L.Z.BUB
I solved it by putting a switch inline on the power source :)
Battery was disconnected over the weekend installing the stereo. Might try unplugging some sensors. I have removed a lot of stuff like iscv, the iscv sensor, all the VSVs, basically all the unnecessary crap. It's probably trying and failing to trigger these, weird I get no codes though.
Link to comment
Share on other sites
No constant to the 12V BATT pin.
Well I wired my loom up to the diagram specs but I'm guessing in the maze of wires there is a constant 12V that I have missed that feeds the ECU memory.
I wired a constant 12V from inside my dash to it but it wouldnt start and I smelled not good smell electrical. So I have run a constant 12V with an in line 10A fuse straight off the battery and it has now started. Without any weird smells.
As the GE ECU's are adaptive every time I have stopped the car everything it has learned has been wiped.
Link to comment
