October 8, 201510 yr comment_700618 Hey guys, My spark plug tubes are worn through at the plug end and no longer seal at the top because nothing is holding them down. Does anyone know part numbers or who might supply them etc. Much appreciated. heres a vid of my KE55 after powerspark ignition mod, and DIY 2 inch exhaust i welded up :P Report
October 8, 201510 yr comment_700619 Sure! 11191-22010 probably available by counter jockeying at Toyota but available inexpensively from here if you can wait a couple of weeks; https://www.amayama.com/en/search?region=315&q=11191-22010 Fitted to these vehicles; http://www.toyodiy.com/parts/xref?s=1119122010&mG=on Good luck! Report
October 9, 201510 yr comment_700623 Chase the 3Y motors in the Great Wall utes, the early ones. They're only a couple of bucks each Report
