Hi Fellas,
I've been trying to figure out which radiator will fit in my KE55 with Sr20de. Measurements for s13 radiator if i set it hard up against the front would be too high for bonnet to close. Are there any alternatives with correct inlet/outlet orientation that will fit or should i try and fit the s13 radiator further back off the rail and put thermos on front?? What have you guys done. Cheers
If it's a stock motor the copper core standard ke radiator would probably do the job.
Ke70 guys use Excel radiators, not sure if they'd fit in a ke3/5* though.
I suppose it depends on where your inlets and outlets need to be though. If the stock rad outlets will work you can get 3 core aluminum rads off eBay to suit.
I've got a repco radiator catalogue that says a KE3x, KE5x radiator is twin core, 467mm wide. The core is 300mm high plus you would need to add about 50mm each for the top and bottom header tanks.
