Box Boy South Africa Posted May 16, 2016 Report Share Posted May 16, 2016 Guys can anyone help me with the wiring under my steering i need a basic diagram for the wire color and what it is for please lights and indicators and instruments acting up. I want to rewire them before i go the way of putting relays on the lights. Quote Link to comment Share on other sites More sharing options...
Banjo Posted May 16, 2016 Report Share Posted May 16, 2016 (edited) Hi Naim, I gather from your Avatar pic & your other posts, that your need for a basic wiring diagram & wire colours, is for a KE70. Altezzaclub has posted just what you wanted back in 2014 in another thread. You should be able to obtain all the info you need at the following link. http://www.rollaclub...ram#entry688373 Trust this assists. Cheers Banjo Edited May 16, 2016 by Banjo Quote Link to comment Share on other sites More sharing options...
Box Boy South Africa Posted May 17, 2016 Author Report Share Posted May 17, 2016 Hi Banjo thanks for this bro will take the whole dash apart this weekend and start rewiring the the faulty wires hope I can do it over the weekend. Quote Link to comment Share on other sites More sharing options...
Banjo Posted May 17, 2016 Report Share Posted May 17, 2016 (edited) Hi Naim, When you get the wires repaired, don't stop there. Go for the relay conversion, as you mentioned. It will improve the voltage to the headlights, & light output, as long as you take the relay supply power directly from the battery via a fuse. There are a couple of relay conversion wiring diagrams on this forum. I think Altezzaclub has a good one, I've seen. http://www.rollaclub.com/board/topic/33874-lousy-ke7-lights/page__p__375535__hl__+relay%20+conversion#entry375535 Cheers Banjo Edited May 17, 2016 by Banjo Quote Link to comment Share on other sites More sharing options...
B.L.Z.BUB Posted May 17, 2016 Report Share Posted May 17, 2016 You can buy an entire plug and play relay kit off eBay for under $20. Quote Link to comment Share on other sites More sharing options...
