My Ke70. One Owner Little Beauty... Pics Inside
MickCStephens
Recently inherited this from my Auntie who purchased it new from the local Toyota dealer WESTLAND TOYOTA Werribee. It had been garaged since new and was driven up until 2 years ago when my Auntie gave up driving after a few bingles.
Inside it is very clean and there are some really great parts along with some damaged parts.
I plan to get her running as my daily and slowly clean her up.
Photos below I have not washed it yet. Took some pics to show starting point.
Showing her worst side. Panel damage from 2 years ago from Auntie.
Edited by MickCStephens
Link to comment
Share on other sites
It does look good!
Take the boot rubber off and clean underneath it, check carefully for any rust starting where the panels are welded together. Clean out down in the sides of the boot too, these cars leak rain in through the tail lights and it collects in the boot.
If the frame of the boot or bonnet is detached from the skin silicon them back on, they get real tinny-sounding and are likely to be easily damaged if not a solid unit.
Take the front bunper off and the plastic will ease off the steel frame, which you can then beat back into shape. Same with the back one.
Replace the bent guard and it will be a million dollars!
Look through "The Girls KE70" build in my sig for ideas on easy mods to do...
Link to comment
Looks to have pretty minimal rust. Good platform to build up.
Yeh for its age it has minimal rust visible. Ive found a spot under the fuel filler where it has a couple bubbles though. It was garaged daily over night all its life.
It does look good!
Thanks for the tips. I’ll be working on it slowly as I'm a hopeless DIY person haha... Need to get it started first as it has a tank of stale fuel. Going to drain the tank this sunday, blow out the fuel line and wash the tank with Kero. Fill with fresh fuel and new filter and try fire her up.
Link to comment
If its been sitting for 2 years, change the oil, filter and plugs while your at it. Also, drop a tablespoon of deisel down each sparkplug hole and turn the motor over by hand before you start cranking.
Already been cranking haha
Ill do the fluids once it starts running. Just eager to hear it idle on its own and go for a drive.
Ive checked the oil and all fluids and they are fresh and at normal levels. Will drop the oil and do all fluid changes once it runs.
Link to comment
  • 5 months later...
Ticking sound might be an exhaust leak of sorts. I've struggled with 4k exhaust leaks before, that damn intake/exhaust combined gasket, what a pain.
Gotta have a think about suspension, brakes and the drive line if you are aiming that high. Big dollars and effort in those three words.
Link to comment
Yeh i wont be taking an engine conversion lightly. If its done, ill do it properly and factor in suspension, brakes, fuel system etc.
Ive been a Commodore man all my life but have fallen in love with the Corolla.
Yeh, I'm guessing I have a manifold leak of some sort. Just have been lazy to get around checking.
Link to comment
  • 4 years later...
Holy S**T its been a while since ive been in here and I totally forgot I creating this thread.
A bit has changed since I was here last. The KE70 ran out of rego, rust has set in while it sat for a couple years.
It's time she got some TLC and ill keep this thread updated.
Here are some photos of the rust thats set in. Its bad but can be saved.
Link to comment
