Very Good Point !
Cheers Banjo
  • Replies 45
  • Views 9.8k
  • I personally wouldn't introduced a new igniton system till you have got the original diagnosed. what is the battery voltage, static and cranking? I am thinking the alternator wiring plug may
  • altezzaclub
    altezzaclub
    So, was it running OK when you bought it and before you did the carb conversion?? Started easily and ran smoothly?? Have you changed the ignition system? If it is stock, check that you have
  • rebuilder86
    rebuilder86
    just checking the rotor against the terminal in the dizzy isnt good enough. that for me, has been the difference between the thing starting, or not starting at all. Test for spark, by turnign ign
