6 hours ago, altezzaclub said:
The fuel pump arm has to ride above the cam lobe, so it goes into the hole aiming upwards and you roll the pump horizontal to get it over the studs.
I can't think of anything else that might stop it.
Awesome thanks so much bro!
Do you have to set the timing to tdc for the cam to line up with the pump arm or anything along those lines?
haha. then that means the cam lobe is pointing at the pump so move it another 180. each of these 180 turns will turn the lobe 90 degrees. so soon enough it will make room.
ir ia designes to constanty apply pressure on the arm, so yes u will be tightening bolts against the tension on the arm
4 hours ago, rebuilder86 said:
what a shit around. haha.
in ur original post about the running problems, didnt u mention that u had replaced the pump? how did u do it back then?
I hadn't replaced it, I only removed the original and put a new gasket on there.
Its definitely a vacuum leak/fuel problem.
Carb and intake/exhaust manny weren't even finger tightened down! Explains the bloody massive leak!
On 02/12/2017 at 12:57 PM, rebuilder86 said:
so is it perfect yet? or is it still missing a bit?
Well I need a new fitting for the outlet of the fuel pump as the one that came in the kit was smaller than the housing its ment to thread into. So after I get that fixed it should be mint, fingers crossed
