Search the Community
Showing results for tags 'kp60'.
Gidday guys, I'm having ongoing problems with my little 4k kp bugeye. To save a long story... I'll try generalise this as much as i can. I've been battling pinging issues and now hard starting(also won't idle on its own) So far I've replaced coil, spark plugs(twice) leads, rebuilt the carb, replaced manifold gasket with a one piece(slight vacuum leak from coby headers) I got the motor to run without pinging after i ripped the dizzy out and shifted it around. but the timing was way too advanced so i pulled it out again to restart the process. Which made it worse, it won't idle on its own and the pinging is back. I'm certain I've lined up the dizzy to correct base timing. Also another problem is the points. I can't set them with a wide enough gap(i set them to 0.45) but they keep closing almost shut. I think the cam might be worn down, has slight up and down play too) What is the correct way to install the dizzy if it has been installed back in the wrong way? Fixing the carb did help with the pinging at first but it slowly came back. Would low compression cause pinging? What elsw could cause it to ping its head off? I hope you guys can understand, wrote this out in a bit of a rush. The car runs bloody well other than the pinging, bogs a tiny bit when taking off also.
Gday guys, Jay here. Complete noobie to this forum so bare with me lmao. I recently brought a dream car of mine, 1980 Kp60 Bugeye starlie. 4k motor with twin choke single carb and Gilmore pullies. pretty standard. But To cut a long story short.... I brought this planning to get it road worthy. It ran bloody well up until after I put a fresh wof/reg on her and did a full service. I changed the motor n filter, gearbox, diff oils, plus coolant and air filter. The fuel pump had a slight weep from the gasket so I took it out, cleaned it up and attempted to repair it with some rtv lol. Then later that night when I was out she started idling quite low and rough. Almost to the point where it wouldn't idle at all! What would of caused this? Is there anyway of mucking up refitting the fuel pump? Any input on this would be amazing, miss driving it already and it frustrates me that I can't just fix it.
