The problem with continually moving the insert up with spacers (you can always add a large washer and see what difference that makes) is that you are limiting your piston travel severely, potentially outside what the spring travel dictates it needs to be.
Lots of people blow inserts by bottoming them out on the piston stroke.
You can also have problems with the spring itself being no longer captive
