Electronic Distributor For 4k Engine
As I said this is the way I found it set up on the 4K in the yard and I put it on mine the same, but it is not neccessarily the correct way ?
Thanks again.
Yes, I believe your setup is correct and is the
one used on the stock engine.
I've followed your setup and the engine appears
to run normally, except for some sluggishness
at acceleration and climbing slopes. Maybe my
piston rings are worn, or the vacuum advance
diaphragms are not in very good condition. Fuel
consumption appears to have improved a little.
I'm using one of those metal splitters with taps
found in aquarium pumps for the hoses, so I could
experiment shutting off the vacuum for each port
of the diaphragm. Shutting off the inner stage makes
the engine more sluggish, and shutting the outer one
even worse. So I've opened up both ports.
I tried connecting the vacuum delay valve to
either of the two ports, and disconnecting it,
but there didn't seem to be much difference.
I'll try using the electronic coil later. It comes
without a ballast resistor, so I wonder if adding
the resistor from the old coil might reduce the
current and protect it from overheating.
Edited by Tham
  • Replies 31
  • Views 33.4k
Hi again....
U mention that is was internally ignited....
Does that mean we dun need the coil....
The distributor for the 4K/5K uses an external
coil. Later engines, such as the Proton Sagas
(Iswara models) made after the mid-90's, has the
ignitor, transformer coil and electronic advance all
built inside the distributor housing.
Soon Choi will give you a used coil if you buy
this distributor from them. He gave me one by
Hanshin marked "For Transistor Ignitor", though
it looked very old.
They also have ones with the ignitor strapped
on top of a Nippondeso coil, but he said those
are for other engines.
As I mentioned in my earlier posts, you can also
buy new electronic coils made by Diamond from
most spare parts shops. I've also seen a very cute
transformer coil by Diamond with a ballast resistor,
meant for points distributors, but can also be used
with electronic ignitors. You can buy it at Takara Auto
in Ipoh Road for around $40.
Edited by Tham
dear tham..
i ustand that u bought a 5k dizzy...
what is the good of 5k dizzy compared to 4k electronic dizzy?
will 5k dizzy give better fuel consumption??
another question...
my coil is givin me problem lately.. Miss fires when i switch on the aircond and approach hills...
can i change my coil to a electronic dizzy type and remain with the contact point dizzy??
thanks..
The distributor is more or less a universal type
made by Nippondenso for the K-series engines.
All these electronic ignition units, whether stock
and built into the distributor, or after-market
external type, including those designed by
electronic magazines such as the high energy
unit by Silicon Chip, basically involve a trigger
unit - an LED sensor, magnetic reluctor, Hall
effect sensor or the points itself, and a power
transistor as an electronic switch.
In the more sophisticated designs, an IC regulates
the coil current (as in the Silicon Chip unit) and
electronic advance can also be built in, such as
those by MSD.
Thus the above distributor can be used on the
3K, 4K, 5K and probably the K, 2K and 7K as well.
The electronic coil can also usually be used with
contact points. My brother-in-law had a Mitsubishi
Lancer with an electronic distributor and coil. One day,
the distributor gave way, and he replaced it with
the original points one. Didn't change the coil, and
the engine started and ran normally.
You can buy a used Hanshin electronic coil from Soon
Choi for $10. Or why not buy the Diamond transfomer
coil from Takara Auto ? Very compact unit.
Takara Auto Parts Specialists
11, Jln Bacang, off Ipoh Rd
51200 Kuala Lumpur
Are you sure it is your coil ? Could be your
points or plugs.
Edited by Tham
actually i m confused!! my mechanic said those missfire might caused by
the ballast resistor as it did not performed well in the oscilloscope!!!
and he said it might be due to the vavles not shutting properly!!
if ballast resistor is the cause, then there is no separate resistor sold, so
have to get the whole coil!!
anyway i m planning to change my distributor 2 the electronic one!!
i think i ll change the coil first than go with the distributor!!
a bit tight budget bcos goin to upgrade to K50 5speed g/box next month!
thanks!
Edited by rsdn
hey the dizzy in those photobucket pics is for a 4kE or 5kE, not sure on the 5k as we never got the 5k
it's the same dizzy daisy uses
the one pickup fires the coil
the other pickup fires the injectors.....fyi
btw; you can leave the inner connection disconnected, the retard just helps for emissions on deceleration. however the advance could be too high without it
Edited by mikeys toy
It only had two wires coming from it and they were both connected either side of the coil, one to
+ve and the other to -ve.
So I guess each wire was for a pick-up?
Do you know which is which, or if it even matters?
Cheers, w.
the part under the smaller plastic cover is the reluctor (or whatever these things use to trigger the signal), and the larger plastic cover is over the internal ignitor. i think it does matter which way they are wired up. i have the wiring connections written down around here somewhere...
the 4k electronic dizzy's i have seen, run a seperate external ignitor attached to the coil.
Why don't you ask him to loosen the valve
clearances then ?
But I doubt if somewhat tight tappets can
cause misfirings when the engine is under
mechanical or electrical load.
Sounds more like an ignition problem.
separate resistor sold, so have to get
the whole coil!!
My usual spare parts shop in Segambut,
Sheng Hua, showed me a Hitachi coil without
a ballast resistor the other day, model C1Z-500.
Probably has resistance wire in the coil windings.
Cost about $40 again. Can be used with both
points and ignitors, I believe. Should be a good
choice.
ya tham... might be goin with the hitachi coil u mentioned....
take care... goin back home town ipoh 4 holidays....3 weeks...
catcha guys later!!
This was taken from the Hayne's manual on
the Toyota Starlet. I think it was based on
the 4K-E engine.
http://i113.photobucket.com/albums/n234/THAM_4K/DIST.jpg
http://i113.photobucket.com/albums/n234/THAM_4K/DIST1.jpg
The electronic distributor looks basically
the same as the ones which some of us
have here.
The connection diagram is for fuel injection,
but note that the vacuum advance for the
distributor's lower stage appears to be
taken from the intake manifold, with the
upper one going to the standard vacuum
inlet above the throttle butterfly.
  • 3 months later...
will this electronic dizzy fit a 3k and what model car do they come from i don't want to sound dumb but if i don't ask i wont know and I'm new to corollas and can't find a closer thread to ask this question in :)
Hey guys, I've been getting some conflicting information and decided to ask here for a definitive answer.
I've got an electronic distributor and i read on the boards to run a gt40 coil. But i've since heard that these fry the dizzys after about 2 months as the lekky dizzy wasnt designed for the higher voltage coil. So does anyone know what coil i should have?
Cheers Justin
