parrot Posted September 4, 2020 Report Posted September 4, 2020 Has anyone worked out a source or way of replicating the red moulded hoses used from brake reservoir to master cylinder, and for carb and PCV applications? Quote
ke70dave Posted September 4, 2020 Report Posted September 4, 2020 (edited) Years ago I bought some seriously gnarly high pressure and high vacuum and resistant to everything hose from a truck spares shop...it was red. I used it for an oil drain on a turbo though. Edited September 4, 2020 by ke70dave Quote
parrot Posted September 4, 2020 Author Report Posted September 4, 2020 These are the sorts of one’s I’m talking about. Not my engines unfortunately Quote
Banjo Posted September 4, 2020 Report Posted September 4, 2020 Hi Pete, Have you tried these guys in Castle Hill, in NSW ? https://automotivesuperstore.com.au/performance/hoses-kits/silicone-hoses Cheers Banjo Quote
kickn5k Posted September 4, 2020 Report Posted September 4, 2020 You can get the hose Dave is talking about here. https://aidex.com.au/ It won't come with the bends though, being they are less than 1km from work if you need I can run over there(on a day I'm working) pick some up and post it to you. Quote
ke70dave Posted September 5, 2020 Report Posted September 5, 2020 Yer looks similar i think. That says 100degc. Mine was definatly for hot oil so could be 150-200deg. But that stuff would do for what parrot wants (though it doesn't specifically mention vacuum) Quote
