June 4, 200620 yr comment_121095 I've put a 4K into the KE36. Problem 1 - it will crank over but wont start - Car is getting fuel, spark plug leads are in the right firing order, it is getting spark. Problem 2 - I have a steady stream of oil pissing out from somewhere. I've i can't get it going i'm really tempted to sell it off..... So can someone please shed some light onto why it wont run? Cheers Mick Report
June 4, 200620 yr comment_121096 where is this oil coming from ?! as in how do u know its a stedy streem- is it leaking onto the driveway? is it pissing onto your bonnet ? Do a compression check - you need the 3 basics for a car to run (well, to an extent...) 1) Compression 2) Spark 3) Fuel Find out where the oil leak is coming from, its a 4k, there not too big a motor ! Report
June 4, 200620 yr Author comment_121108 can't actually see any visible signs of oil anywhere on the engine. All i know is its leaking onto the crossmember and then pooling on the floor under the car.... As for spark and fuel, i have both of those.... Compression check I can't do cos I don't have anything to check it with :monkey: Report
June 4, 200620 yr comment_121241 leaking onto the cross member - well, i suggest u either wash the motor down, or get a light and have a look at the sump / headgasket / rocket cover gasket / spark plug tubes. theres not too great a list on a 4k where oil can come from :monkey: Go get a cheap compression tester from supercheap. Wont set u back much. Report
June 4, 200620 yr Author comment_121249 I'm thinking sump as it only happens when oil pressure is increase from cranking the engine over. My next questions - can the gasket be replaced without having to pull the engine out again? Report
June 5, 200620 yr comment_121301 You can take the sump off a K engine without removing it...but it is a c**t of a job...Just pull the engine out and replace every gasket...Save yourself more stress...it takes 20 minutes to pull a K engine out Report
June 5, 200620 yr comment_121365 use ur thumb as a compression tester, will soon tell you whether you have compression or not. have you set the timing correctly? Report
June 6, 200620 yr Author comment_121579 Its all working. The oil pump wasnt aligned in the right spot to get the rotor button lined up with Piston #1 on the dizzy cap. After much aligning and messing about it fired up today. Now to just fix that oil leak from the oil filter bracket..... Report
