June 21, 200620 yr comment_124564 Hey this has been a recurring problem for me I own a Ke70 1983, and every now and then when i start the car it is like the ignition is dead and just clicks. I have had like 3 different auto electricians look at my car the first one replaced a relay saying I had a voltage problem. The second one did the same thing plus did something to the starter motor and the third guy told me to buy a starter motor which i did and he did something to the solarnoid on the starter motor. Now the same problem has come back a month later and I'm wondering am I getting screwed around by these auto electrians or is this problem happening due to something completely different. Does anyone know what i should do about this problem? thanks Report
June 21, 200620 yr comment_124577 This seems to be a common problem I've encountered when dealing with k-series engines. The first time it happened was in my ke70 i had a few years back. To fix it i got an auto electrician to wire in a relay for the starter motor. The problem was fixed and never came back. I think the problem is that the starter motor isnt getting enough current to actuate the solenoid. THe second time i encountered the problem is my current car, my 5k ke20 and its only just started doing the same thing. I'm just living with it at the moment cause I'm lazy :) hmm but you say youve already been to an auto electrician that put in a relay so the problem might be somewhere different to mine. Report
June 21, 200620 yr Author comment_124588 I have been to three different Autos that what you are saying about the starter motor relay is what the last guy sort of did. The car has been running good until today. I think I will take it back to him he said if it was his work he will fix it for free due to warranty reasons as it has been a mont, but i don't want the same problem happening again down the track as it has been since December last year. Report
June 21, 200620 yr comment_124591 I think it is a common K motor problem, Mine used to do it till I put the relay in.. Report
June 21, 200620 yr Author comment_124595 For Trev I'm from Ipswich i find the problem to be a hassal as I have to keep sparking a wire against the battery to start car, and you guys should know how hard it is to start your car when it is cold. It is a lot harder to start with a wire and being cold Report
June 21, 200620 yr Author comment_124597 the first Auto did that put a relay in and the problem came back a month later Report
June 21, 200620 yr comment_124602 can't say i have really had that many starter problems.... does the starter have a heatshield on it? has the car got extractors? Report
June 22, 200620 yr comment_124695 me ke70 does this too, just clicks when you change the ignition to 'start'. I keep switching it to 'start' quickly and it starts pretty easily when it finally breaks It'll be fixed! Report
June 22, 200620 yr comment_124714 i had this problem as well. fixed it when i put a denso relay in the fuse and relay panel beside the battery. the australian ke70 only has a heavy jumper wire were there should be a relay, just pull the wire out and replace it with a DENSO relay. if that doesn't fix it you've got other problems. Report
June 25, 200620 yr Author comment_125175 don't worry guys thanks for your help but Trev sorted the problem out for me Report
