My Car Is Idling Funny :s
hey i just fitted a sc 14 supercharger to my 4k and it is idling funny like it picks up revs then looses revs and nearlly stalls the it repeats i have no idea y if anyone can help me that would be great thanks johnny t
  • Replies 32
  • Views 6k
Is the charger running constantly?
yep
Its leaning out and it might be pressurising the carby, have it so it turns off at idle and only comes on when u need power.
yeah but i got my fuel pump hooked up to the same swithch but i wanna change it..i can hook it up to the ignition cause the balist risister hasnt got enough volts to run it so i gota have it straight to the battery
Run it on a relay, I did this same experiment on a D15 civic engine (dual carbs, 1.5 OHC) with a force flow and it stalled/ran crap at idle.
but i think I'm gonna have to hook up another switch and run the fuel pump and the sc on diff switches
Edited by johnny t
Make up a throttle position sensor and make it rely on your acceleration
how do u hook up a throttle posotion sensor??? felix ill get bak 2 ur questions in a sec
u can get pressure switches (a few different types) and you make a bracket so that it fits in next to your accelerator linkage on the carby, i will try to find a diagam.
hey felix my is a draw thru set up and what is a rising rate FPR?
sc 14, is that off the 4agze or the 1ggze?
and do you need to run a supercharger like a airconditioner sort of set up?
4 agze i have no idea bout the air con set up
Edited by johnny t
