Story time! This is my 1988 Toyota Corolla SR5 AE95 4WD. I went on the hunt for one of these in July 2021. Looked for about 6 months and only found 3 in that time. 2 were full of rust which I wasn't interested in taking on. This one popped up with a issue where it wouldn't go into gear. (manual) Owner wasn't sure if it was a gearbox or clutch issue. The car had a lot of work done by the previous owner so I decided to jump on it. Ended up paying $1400aud site unseen as the car was 700km away from me. Paid another 700 to get the car to me. Car arrived in my possession October 2nd 2021. Overall very happy with the purchase! Diagnosed it as being the clutch due to being able to start the car it in gear. The old 4AFE didn't run the best, after swapping heaps of parts over trying to diagnose the issue I gave up on it and started looking at engine conversions. Actually came across Kevins build thread on here with his 7AFE AE95 and with me actually having a spare 7AFE here it was obviously meant to be! Was nothing wrong with the 7AFE but ended up stripping it down, chucking a full gasket kit through it, new water pump, Gates timing belt kit, Exedy HD clutch, rear main, crank and cam seal, etc. Had some personal things come up and lost interest in it for a while there, but back in full swing now, been really getting into it over the past few months. It's so close to being done and so keen to hit the beaches and trails in the old girl!
So here is a few pics of the progress so far!
The day she arrived!
245938413_5160405700653581_1155201921379262809_n.thumb.jpg.91e545d26a0a45b43ba2f649d5ff2f14.jpg
The 4AFE
246351276_5160404660653685_2730080231535827046_n.thumb.jpg.ed54ced8caf61ffd25665174e8f5db03.jpg
Coming out!
275287133_5651844641509682_1573612234613849869_n.thumb.jpg.35c0ee7868f337fca09e164fd744455b.jpg
The 7AFE
266366684_5331080296919453_2611361555423267367_n.thumb.jpg.b974204d418027815ba9a6d9fd3ec406.jpg
Coming along nicely.
272833783_5539671942726953_4352152309217538590_n.thumb.jpg.3db569158e3cedb3fa49b984a1257978.jpg
And ready to go in!
343305836_906152290612300_6949729719044439932_n.thumb.jpg.fec56085dd07e3b6fc993cc011dd3d82.jpg
Clutch on!
344433069_1023311058641524_838921798715018833_n.thumb.jpg.245dbda5df319e5ed98b485a4b4dfb60.jpg
Gearbox on, was such a tedious job but we got it done!
345456148_786877959662564_5665095086621750635_n.thumb.jpg.c7817d6d83333b3439d94fc6c6cc7c51.jpg
While the 7AFE is a notched block like the stock 4AFE it still required some grinding to clear the 4WD transfer case.
345442944_114907214909421_6880655874959728856_n.thumb.jpg.a6b00c91f07d7d3075064e2f92385d52.jpg
And now shes bolted up in the bay! Still got a fair ways to go but loving the journey! Have all new bushes, wheel bearings and ball joints for the front end. And did the inner and outer rack ends and rack bushes while the engine was out. Also repainted the bay!
346467686_6379826568741867_6648278957588778757_n.thumb.jpg.6f70e652efd59175ccfe97fe0647c21c.jpg
Cheers for reading! Will update with more as I go!
Edited by RAT_SECA
Just another post regarding the mods by not the bloke I bought it from but the bloke before him. Actually got in contact with him shortly after buying the car and got some photos and more info off him.
So it's got Dobinsons springs front and rear. Front are TN Magna springs (C43-038) which give roughly 1" lift and it has a 2" strut top spacer. Rear is what I believe to be EL Falcon springs with stock gen 1 Rav4 shocks which are 3" longer than standard AE95 shocks. Rear end also has custom adjustable upper control arms and panhard rod. For those that don't know, the rear end on these are live axle coil sprung. Future plans will be to get some more flex out of the rear end. I will be removing both front and rear sway bars. (car won't be daily driven so shouldn't need them.) I actually live in the town where the Dobinsons Springs production warehouse is so will be making a visit to them to try and find a slightly longer rear shock. I also plan on going 27x8.5 R14 Kumho MT tyres in the future. Current tyres are 185r14 Maxxis MT753's.
I'll throw in a couple pics from the previous owner and the journeys he took it on.
343556420_191258640405099_5988675608516569483_n.thumb.jpg.c89d83fd211e1b949b6f7d06741a2f6a.jpg
18010931_1137149993096844_5995627061844686803_n.thumb.jpg.f75eadda012fca90ca2f83cc03749d46.jpg
345465422_140372102284174_8984700465529454209_n.thumb.jpg.a801b8f99f282f1c38302c83ada38e85.jpg
I'm up in Central Queensland Australia so pretty cool that it has been so far south as Coffs Harbour NSW
343558354_531738405840987_1956777932097659448_n.jpg.7a1101b29bbca3b7d3a0c1b6db3ff090.jpg
Edited by RAT_SECA
  • 3 months later...
 Another update! She's back on the ground for the first time in over a year!
Also sound deadened/underbody sprayed the lower radiator support and inner guards.
fetch?filedataid=32107&type=large359858503_7244562755571188_4286200284332802289_n.thumb.jpg.900a8d7a3122458b7ac0983a88a0eee2.jpg
Colour matched the upper radiator support (weirdly from factory they are black in the centre.) And motor is almost completely back together! Big thanks to forum member Kebin for doing the wiring harness!
fetch?filedataid=32108&type=large372845418_265526862951031_8365456527783672797_n.thumb.jpg.d74ee37aaff44a30d8db7617f2526ca8.jpg
Have done all new front wheel bearings, bushes, ball joints and brakes. Once I have it running I will be doing the same to the rear! Will be like a brand new car when I'm done!
373026198_1355322275063110_1225725840855509945_n.thumb.jpg.1a0d5ca4d40483adbcc7dc15f903f7c9.jpg
Also scored a parts car for free. She has a blown clutch, water in the motor and the radiator support has been pushed upwards. She will donate a few pieces to the build!
Check out the height difference from stock to lifted! Roughly 4.5" higher taking lift and tyres into account.
  • 4 months later...
Big update on the old girl! She is 95% finished, just a few small things to do. Had some dramas when I first started it, started, ran for 30 seconds and then died. The engine had the same drama in the donor car which the previous owner of that thought it was fuel pump. I did end up doing fuel pump in this one any way as well as distributor. Ended up finding the culprit being the ECU had shorted out in the injectors circuit. All fixed now and running great!
Front end started going back together.
404893327_7729585073735618_6027304990775042050_n.thumb.jpg.479697ca928c41f981f1fbba9d83d074.jpg
Wanted to fit up a snorkel but wanted to go something that looked as OEM as possible. Found that it was common to use a D21 Navara/Pathfinder snorkel overseas so ended up buying one from Malaysia and having it shipped over to Aus!
Obviously because it's for a different car the template was pretty useless so I test fitted it a few different ways on a spare guard first to get the final measurements.
Obviously not perfect but I love it!
412708129_7836294063064718_8606021803404876069_n.thumb.jpg.067cd436c8cd726a5631bae52a0b97e7.jpg
412290594_7836293369731454_8959841493701549265_n.thumb.jpg.c503bf743d4bf359e696c998bad7ef48.jpg
412706779_7836293589731432_2454433032511885479_n.thumb.jpg.68828722b21fe095703266822cd40abe.jpg
415466331_7871635839530540_8425861865596181988_n.thumb.jpg.753c7bfd6365e62b5e0a82900ecced21.jpg
416306254_7871636052863852_4868457660486821253_n.thumb.jpg.d68cc149ae5351e2ef02a59aa5749654.jpg
Set out to start on the interior, JRP gauges in and I decided to delete the ash tray and the cigarette lighter and instead fitting up a USB charger and mounted my UHF in the ash tray slot using a bracket I made up.
416330196_7871639216196869_1905596679260448023_n.thumb.jpg.a95d3f0b36fceca17b54743decaf7895.jpg
415497496_7871639282863529_9097706925717843933_n.thumb.jpg.9a57b8d606f363a436fb30ac375b2abe.jpg
Not much longer to go now!
  • 4 months later...
Well BIG update, long story short she is finished and now registered! Here's some photos from it's shake down trip!
Started off at a spot out of town for sunrise.
441673378_824262876436947_862355128730430708_n.thumb.jpg.184ce3b535d219bfdb4cffb9cdfb834b.jpg
Then went down onto the beach!
441582422_357233153646111_5815169496419387688_n.thumb.jpg.57bdc07ae57eeb6f2d7ee8d6af034cde.jpg
436712804_777820371220369_1220828083503731338_n.thumb.jpg.427bea245591cd1f395f66b949b4d507.jpg
Here's a shot of the finished engine bay! Also fitted up a D21 Navara/Pathfinder snorkel! Fits really well and gives the factory look I was going for!
441906805_1385424165479256_5513850986349119114_n.thumb.jpg.4d92f5aa51ba2eff450e8be67739d2a8.jpg
Fitted up some flush mount LED reverse lights in the rear bumper.
441579484_822324939486459_6224343358472642282_n.thumb.jpg.7648abf7fc8c51179ba6694381aa8eeb.jpg
Really enjoying exploring in the old girl, a few more trips coming up soon!
441900958_282500868191423_1789578863099883774_n.thumb.jpg.b42d6f2745dfdfd3800d3a8b26926f21.jpg
  • Like 1
Just love it, when a project comes to "fruition", & the road trips get going, under it's tyres !
Well done, & a good thread.  I'm sure it will be appreciated by many, over the years on here.
Congrats
Cheers Banjo
  • 3 months later...
Hi Daniel,
                   It's Saturday morning, & although I saw Your latest post yesterday; I just took the time to read right back through your build, from when You first posted, 15-16 months ago.   It is a wonderful build, & a beautifully, finished project; with attention to detail, which adds to the quality of the result.  You should be very proud of yourself, & trust You have many, many, happy trips & memories, with it, in the future.
Cheers Banjo
