Drill press is always the best. Centre punch, small drill then work your way up, with larger drills, until it's the right size for the tap, for your particular fan switch.  Many of those brass switches & temp sensors, have a tapered thread.   Never ever leaks !  That's why they are tapered, so they basically "jam tight", as You screw them in.
Cheers Banjo
Edited by Banjo
"What do we think about a beams 3sge swap? "
Its been done plenty of times, but the Beams is a very tall motor so either a lot of work to get it low, or a hole in the bonnet. I'm working on putting one in an AE86 Sprinter for a guy right now, a gravel rally car, and it has a Kiwi-made shallow sump and custom mounts. A pair of brothers who rally a KE70 used the earlier Gen 4 version for exactly this reason.
Anyway, that's a long way down the track, you can make that 5K go fast enough to get into trouble!
If you're screwing a tapered brass fitting into an aluminium housing use some sealant and only go just above hand-tight. Those t'stat housing are fairly thin to start with and often corroded even thinner. I pulled the thread out of a 4AGE one and found it was made of unobtanium, but luckily could extend the thread further in.
Hi Thomas,
                   Have You ever watched this guy on utube, regarding his assessment of all Toyota engines. He has a few videos, & is widely followed.
Toyota Engine Assessmets
In one He talks about the incredible reliability of the 1NZ-FE & 2NZ-FE engines, fitted to Yaris, Echos, & Corollas.  I once looked at the possibility of the 1NZ-FE  transplant to a KE series Corolla, after I purchased an Echo, for my daughter.  The big problem, is it is an east/west engine, & needs some serious mods to fabricate mounting points.  The other problem, is the inability to mate an inline gearbox & clutch, to the 1NZ-FE, without an adaptor; which I don't think still does not exist.
I did a couple of Google searches, & strangely came across a thread on RollaClub, back in 2017, where a number of us; weighed in on this subject.  I'd forgotten, all about it.
You might like to have a read, at this link.
https://www.rollaclub.com/board/topic/73681-cheap-4ks-maybe-not-anymore/#comment-712069
Cheers Banjo
Edited by Banjo
To be honest, I’ve only ever had starlets with k series motors in them and when I look back I wouldn’t have changed anything ay. They’re an epic package, simple, and a heap of fun as is with some noisy/peppy upgrades.
At the moment I just wanna turn the key and have a tidy example starly with a few good supporting mods/updated tech where necessary. Take it hooning and keep things simple…famous last words hahah
I’ll look into that YouTube channel, I’ve also got a donor 4 door flat front shell that has some rear roof corner rust that needs addressing but it’d make a good track/event platform someday.
also re the thermostat top housing, I found one… a factory RHS shooting outlet with a facto sensor tapped in.
will update with pics when it arrives from chch.
also a little unrelated, I’ve got the motor on the stand (no oil in it). It’s got a new filter on etc and is waiting to go back in the car basically in a couple months. Should I dump the oil in and give it a wind over each week? I was gonna send some down the spark tubes but being dished pistos I wouldn’t reach the walls without dumping a good 100ml in hahah
I'd get some CRC 556, WD40 or Q20, whatever and squirt some in with the extension tube on the valve. If you spray the far wall it will run around the rings and coat the cylinder walls as you turn it over. Only needs it once every few months. The 90% kero spreads the oils around and then slowly evaporates, and it will burn out when you start the motor.
I've always used light sewing machine oil, like you get in those little household size tins. Like Altezzaclub says . . . spray it down towards the sides of the walls of the cylinders, so it get into the ring gaps etc. The real danger with old engines sitting around, is when the spark plugs are removed permanently for storage. Screw them back in.  Plug exhaust & inlet manifold with wrag to stop air entering there, as there will always be some valves open, allowing outside moist air into the cylinder proper.
If the head has been removed, smear grease into cylinder walls, & around the top edge of each piston.  They can store sucessfully for years like that, as it prevents "moist air" acting on the cylinder walls.
Cheers Banjo
