Quote
To be honest, I’ve only ever had starlets with k series motors in them and when I look back I wouldn’t have changed anything ay. They’re an epic package, simple, and a heap of fun as is with some noisy/peppy upgrades.
The Starlet marque has been around almost as long as the Corolla name.  I know there are far more of the Starlets in Kiwi land, than here in Australia.  Because they retained the rear wheel drive, for so long, & they were very popular in Japan, for road racing; that resulted in there being a lot of "after market" sports components manufactured, including suspension.  Starlet bodies, also have been modernised over the years, & I believe a Starlet GTR or something special, is being planned for release in 2026 ?   https://www.drive.com.au/news/2026-toyota-starlet-rumours/
There are also lots of special panels available, if You want to go all the way.
The Starlet, with a wheel in each corner of the car, made it a wonderful rally platform, with little overhang, & lots of aftermarket suspension parts available.  Twin OHV engines were also a popular upgrade.  Not quite sure how resistant to rust, there are; compared to the KE series Corollas ?
https://www.my105.com/search/details/1982-toyota-kp-starlet/057f5777-9c4b-46cd-beda-0ca0c2b0cc8f
I'll leave You with this one !
https://www.tiktok.com/@twinenginecorsa/video/7374758402427309345
Cheers Banjo
Edited by Banjo
  • Replies 35
  • Views 4.4k
That oil pump has seen some rubbish go through it! You should have a flat sheet of half inch thick steel in the workshop, maybe the size of an A5 sheet of paper. You wrap a sheet of 180grit wet 'n dry sandpaper on it, spray some CRC on it and wipe that oil pump base around and around until the grooves mostly vanish. If you're keen, take the pump off you can do the bottom of it and do the impeller too. Then clean them all really well!
Anything that needs to be flat can be sanded, like a thermostat housing that has had the aluminium pulled out of shape by some guy with big spanners.
There will be a gap listed in the 4K manual for the oil pump rotor tip clearance. A thou or two I expect.
Hey fellas,
tezza - to be honest mate that’s probably a little out of my wheelhouse at the moment. This motor I presume will be pulled late next year for an overhaul at a local legends (Charlie b) workshop so I’ll leave that one for him.
The thermostat housings have arrived and we’ve got two options. You should be able to make sense on what I’m talking about from photos attached.
Option 1: has a temp switch hole tapped in already, but the outlet diam is small than our other option…
option 2: tap a hole into the housing with a larger outlet. This outlet will match the rad inlet
what do we think about this?
I don’t think it’ll make a such difference but in a perfect world I'm thinking tap the bigger outlet
cheers fellas, input much appreciated as always
Hi Thomas,
                     Yep, the one with the larger outlet, would seem to be the way to go.  However, if it was me, in your shoes; I'd give both top outlet sockets a really good rub back with a rotary wire brish, on a drill, & then take a look to ensure there isn't any unseen corosion, that may compromise your project.
A brand new 80 grit emery paper unside down, on a hard flat suface, show clean those gasket flange surfaces up sufficently ?
Cheers Banjo
Edited by Banjo
No, if you drill the larger diameter one you will find its only a few mm thick, nowhere near enough to carry a thread.
Clean them both up with a wire brush and dig out all the corrosion holes and see how bad each one is. It wouldn't be the first time I've filled the craters with body filler and had them last for years. The bigger one is the ideal one obviously, but any temp fitting will have to go in the head, where the alloy is thicker.
The best idea would be to buy an in-hose fitting, I've used them for years.
https://www.ebay.com.au/itm/225253674996?chn=ps&_ul=AU&_trkparms=ispr%3D1&amdata=enc%3A1Im-dDrB5R7C86KkC0s-uAw42&norover=1&mkevt=1&mkrid=705-139619-5960-0&mkcid=2&mkscid=101&itemid=225253674996&targetid=2367800370202&device=c&mktype=pla&googleloc=1000339&poi=&campaignid=21776442415&mkgroupid=173963205248&rlsatarget=pla-2367800370202&abcId=10047386&merchantid=7667992&gad_source=5&gad_campaignid=21776442415&gclid=EAIaIQobChMIsPrt9KeWjgMV9yutBh11xhHNEAQYASABEgLGPPD_BwE
Hi Thomas,
                   I've used both solutions on one of my test bed engines.
The one on the aluminium spout switches the electric fan, & the one Altezzaclub suggested; I use to log the coolant temperature on an independant temperature data logger, so I can see exactly what the cooling system is doing.
Cheers Banjo
