So why were K series engines just so good in their day, with so many still out there adding 1000s of klms to various cars ?  I Asked this question of A.I. & You might like to read it's reply.
Quote
why were the k series engines of the 1960s & 1970s, so reliable ? was it because of using basic designs from british manufacturers like austin & morris ?
The Toyota K series engines (1966–2007) are legendary for their reliability due to
simple, over-engineered designs and conservative performance targets. While they shared the basic Overhead Valve (OHV) pushrod layout common to British manufacturers like Austin and Morris at the time, they were original Toyota designs from the Kamigo plant in Japan, not direct copies.
Key Reasons for Reliability
  • Simple Architecture: The K series utilized a basic 2-valve-per-cylinder pushrod (OHV) design. This meant fewer moving parts, no complex overhead cams, and fewer failure points compared to more advanced engines.
  • Robust Construction:
    • Cast Iron Block: A rigid, thick-walled cast iron block provided extreme durability.
    • 5-Main Bearing Crankshaft: Supporting the crankshaft with five bearings (instead of three common in some smaller contemporary engines) reduced flex and internal wear.
    • Forged Components: Many variants used forged steel crankshafts, which are significantly stronger than cast alternatives.
  • Conservative Tuning: Toyota prioritized longevity over peak power. For example, the 1.3L 4K engine typically ran low compression ratios (8.5:1 to 9.0:1), making it highly tolerant of poor fuel quality and reducing stress on internal seals and gaskets.
  • Ease of Maintenance: The non-crossflow design (intake and exhaust on the same side) and ample engine bay space made them exceptionally easy to service with basic tools.
Design Origins: Toyota vs. British Influence
While you noted similarities to Austin or Morris, the K series was a native Toyota development.
  • The "British" Connection: In the 1950s and early 60s, Japanese manufacturers (including Toyota) closely studied Western designs to learn mass-production techniques. The OHV layout was the industry standard for reliable, "no-frills" economy engines popularized by BMC (Austin/Morris) and Ford.
  • Toyota Production System (TPS): The real differentiator was not just the design, but the manufacturing precision. Under the "Toyota Way" (Kaizen), tolerances were often tighter than competitors, and any line worker could stop production to fix a quality issue.
Evolution of the K Series (1960s–70s)
Engine  Displacement Years Notable Applications
K 1.1 L 1966–1969 Original Corolla (KE10), Publica
2K 1.0 L 1969–1988 Starlet, Publica
3K 1.2 L 1969–1979 Corolla (KE20/30), Starlet, Liteace
4K 1.3 L 1978–1989 Corolla (KE70), Starlet, Daihatsu Charmant
The Toyota 5K (1983–1996) is the 1.5-litre evolution of the K series, designed to bridge the gap between the economy-focused 4K and the heavy-duty 7K. It is widely regarded as "quietly legendary" for its simplicity and iron-block durability, frequently reaching over 350,000 km without major intervention.
Wikipedia +3
Key Specifications
According to Wikipedia and Alibaba Product Insights, the 5K features:
  • Displacement: 1.5 L (1,486 cc) with an 80.5 mm bore and 73 mm stroke.
  • Output: Typically 55 kW (74 hp) at 5,600 rpm.
  • Valvetrain: 2-valve-per-cylinder OHV (pushrod) with either hydraulic or solid lifters.
  • Block Material: Cast iron block with an aluminium alloy head and a 5-main bearing crankshaft.
    Wikipedia +2
Popular Variants
  • 5K-C: The standard carbureted version found in the Toyota Corolla II and Toyota Tercel.
  • 5K-E: Introduced in 1987, this version features electronic fuel injection (EFI) and electronic ignition, providing better cold starts and smoother idle.
  • 5K-U: A low-compression (8.0:1) variant often used in Toyota Hiace vans or for LPG conversions in taxi fleets.
  • 5K-L: A larger 1.8L–2.2L variant specifically reinforced for heavy-duty commercial use in Toyota Dyna trucks.
Why It Is Highly Sought After
  • Robust Bottom End: Later blocks (post-1987) feature thicker cylinder walls and reinforced main caps, making them far more tolerant of mild performance upgrades.
  • Compatibility: It is a popular "bolt-in" upgrade for older Toyota Corolla KE70 or Starlet models because it shares the same mounting points as smaller K engines but offers significantly more mid-range torque.
  • Industrial Use: Beyond cars, its reliability led to widespread use in Toyota Forklifts, where it runs for thousands of hours in demanding conditions.
    Wikipedia +4
Common Maintenance & Issues
  • Cooling System: The primary cause of 5K failure is cooling system neglect. Experts from Alibaba Product Insights recommend replacing radiator caps annually and using OEM thermostats to prevent head gasket warping.
  • Timing Chain: While durable, the timing chain and guides should be checked every 140,000 km for rattle or play.
  • Fuel Quality: Older 5K engines with "soft" valve seats require leaded fuel or a lead substitute; running them on modern unleaded can cause valve seat recession.
Cheers Banjo
Edited by Banjo
Yep Si !  Made in China.  Following link, indicates You can have one shipped immediately.
https://milexuan.en.made-in-china.com/product/ZFUTSGHcneth/China-Milexuan-Wholesale-1-5-L-Motor-Part-5K-Engine-Short-Block-for-Toyota-Carina-Corolla-Van-Liteace-Forklift.html?pv_id=1jj2s0hfeffc&faw_id=1jj2s1m40724&bv_id=1jj2s1m448be&pbv_id=1jj2s0egvb22
Note last picture in the series shows boxes & boxes of them ready to ship to Tasmania.
Cheers Banjo
I hate A.I.  What A.I.can't do is context.  Overhead cam engines were never a consideration at the time in this class of vehicle.
Unless you could stump up three times as much for an alfa, and you can't consider a Ford twin cam as mainstream.  I think the first volume overhead cam engine cam with the pinto?
' I think the first volume overhead cam engine cam with the pinto? "
That was 1970, long after Datsun's L-series OHC, which they copied of Mercedes..  Maybe the belt instead of a chain was new.
Well that was a bad mistake, considering I owned 3 Datsun 1600's in the mid 80's!
