love ke70 Posted October 6, 2006 Report Posted October 6, 2006 right, well it was all in and running, rwc booked for 8 in the morning on thursday i tow it down to the servo as i ran out of gas the night before hehe try to start and it wont feels like cam timing has gone all wrong. get all upset angry emo and then just determined to fix it tow it home, find an effed oil pump pulley (Will get pics) what happened was the nut that holds the pulley on stripped the thread on the shaft, and worked its way loose, and then the pulley has come loose and the centre of the pulley turned to filings inside the timing belt case = big mess! sooo I'm like alright, go get new pulley, create new thread and put bolt on, should be done in an hr or 2 WRONG go to toyota...oh yeah, thats 150 just for the pulley, ex japan so thatll be 3 weeks. i walk out do some wrecker hunting to no avail so I'm like "ahh, tim had that n.a. 1g that he uses for spares" call tim, tim still has the oil pump and pulley but the motor is in storage, 5 minutes from where i am but he has the only keys so i drive like 30 minutes to tims, then he has to go get his payslip n shit so like 2 hrs later we arrive about 1km from where i called him to ask about the pulley so, we dick around, get the oil pump and pulley off the motor, i go home and find that the n.a and turbo oil pumps are different and not even the centres can interchange so I'm like ok lets just put the pulley on the old pump like i originally planned.next paragraph.. turns out the pulley i have now got has a D shaped hole, just like the turbo one only the hole is 1mm smaller so I'm like cool, ill take this to the engineering place and get them to machine the shaft to fit this new pulley and put the thread on to suit a nut i found up so go in, the guys like yeah thatll be about 30 dollars and be ready at 10 tomorrow (this was thursday afternoon) so i go in this morning and hes like, ive done the work but theres a problem, and he shows me. puts the shaft in the lathe and sets it spinning, and it runs fine, no wobbles puts the new pulley off the n.a. motor onto the shaft and spins it again, pulley is wobbling side to side and this is only at 750 rpm lol so I'm like ah fark go to my local wreckers and spend an hr hunting thru motors and find a 3sf with a oil pump pulley on thats only a little bit smaller. so I'm this will do then spend an hr to try and get it off before i get some mofo with a rattle gun to do it in like 1 minute lol so 10 bucks later i have the 3sf pulley, which thankfully fit the now machined shaft and we put it in the lathe at home and it spins just fine so I'm like yay is about 1 by now so I'm like ech, lets get to this, have everything back together by 3.30 start her up and am planning to get the rwc this afternoon BUT the timing belt upper case melts the f@$king timing belt so i have to now space that coz its started rubbing, and then ill be all good :2thumbs: think i may have cooked the turbos with the lack of oil pressure hehe, ill give it a good run and see if it was all jus lag i was gettin in the backyard or what, it started to make boost but i had to shut it down coz i was running out of green anywho, I'm gonna shutup, feel free to say nothing, i just thought someone might like to know my 1g is more evil than most other motors... Quote
Medicine_Man Posted October 6, 2006 Report Posted October 6, 2006 Ask Teddy about my cursing and swearing at my 4AGE, And it is the "Bolt in" conversion.. Quote
Des Posted October 6, 2006 Report Posted October 6, 2006 Bad luck eh, Anyway let me know if ya want another roady booked in. :2thumbs: Quote
Jason Posted October 6, 2006 Report Posted October 6, 2006 i know what your feeling one thing leads to another. Ive had to complety custom build almost every part on my ze... Quote
skiddz Posted October 7, 2006 Report Posted October 7, 2006 see i told ya it was a homo engine :D , but noooooo luke is never right is he, on another note give me this now bastardised 1g and ill give you ur choice of a hassel free 2t, or a even better neeeessan poosar :2thumbs: :n: Quote
love ke70 Posted October 7, 2006 Author Report Posted October 7, 2006 you wouldnt know what to do with it lukey boy lol its all sorted now and shit it does hard for only 5 psi of boost Quote
love ke70 Posted October 9, 2006 Author Report Posted October 9, 2006 and the aftermath two f@$ked turbos i wanted to do a single upgrade anyway but 1ggte with no boost = BORING! so bring on a job and a great big garret GT3071R Quote
love ke70 Posted October 9, 2006 Author Report Posted October 9, 2006 lack of oil pressure for too long = f@$ked bearings should hear them tryna spool lol scary :y: Quote
Corolla_Kid Posted October 10, 2006 Report Posted October 10, 2006 I know absolutely nothing about turbos but surely it would be cheaper to replace the bearings than convert to single turbo setup? Quote
love ke70 Posted October 10, 2006 Author Report Posted October 10, 2006 this is true, but i would likely have to buy genuine spares so it still wont be cheap the stock turbo layout is a c**t to deal with in the ke70 engine bay (one of the hard line oil returns goes AROUND the steering arm and its impossible to do anything to them with ease the ct12's are very small and have to be worked very hard to make decent boost and likely wont last very long they are also a rather resrictive design so all in all, you can see why I'm doing this upgade now rather than wasting more money on crappy stock twins Quote
Jason Posted October 10, 2006 Report Posted October 10, 2006 (edited) how about bigger twins :P or sequential :y: Edited October 10, 2006 by Jason Quote
irokin Posted October 10, 2006 Report Posted October 10, 2006 how about bigger twins :P or sequential :y: Because you almost double the cost in turbos....then youve got custom manifolds, two dumps, custom cooler piping and then trying to get the bloody thing to run correctly (with sequentials) Quote
love ke70 Posted October 10, 2006 Author Report Posted October 10, 2006 theres a bloke running bigger twins, 2 T25's in fact and he can't get much more boost than 20 odd psi because thats the maximum one of the turbos can push putting 2 together doesnt make them able to make more boost. sequential = how the hell would that fit in a ke70 bay? :y: ive had enough dicking around, doin it proper like this time :P Quote
