Jul 4 2010, 03:20 PM
Post
#1
I'm new here ![]() Group: Members Posts: 4 Joined: 7-August 09 Member No.: 8931 Last Active: Yesterday, 07:27 PM |
hey all,
i was just wondering if anyone has done this personaly because i have heard alot but have not seen any finished projects. i am looking at doing this myself ( only because it seems easy ) but i don't want to rip my 4k out for nothing thanks in advance |
Jul 4 2010, 04:21 PM
Post
#2
Regular Member ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 279 Joined: 8-March 10 From: Tas Member No.: 10543 Last Active: Today, 12:10 AM |
hey all, i was just wondering if anyone has done this personaly because i have heard alot but have not seen any finished projects. i am looking at doing this myself ( only because it seems easy ) but i don't want to rip my 4k out for nothing thanks in advance I wouldn't say it's ripping your 4k out for nothing. If you actually have every other component set up to do a CA18 conversion and the only thing you have left to do is a few mounts, then you're laughing. -------------------- |
Jul 4 2010, 05:49 PM
Post
#3
![]() it feel's hot in hear ![]() ![]() ![]() ![]() Group: Regular Member Posts: 108 Joined: 5-April 10 From: sydney Member No.: 10770 Last Active: 16th August 2010 - 06:38 PM |
hey all, i was just wondering if anyone has done this personaly because i have heard alot but have not seen any finished projects. i am looking at doing this myself ( only because it seems easy ) but i don't want to rip my 4k out for nothing thanks in advance i know it's not a ca18 and the 4k mount's been cut down a bit but you can see the rb20 mount slides into the 4k one you have to grind the little tab off the rb20 one and grind the 4k side a little, as for a straight bolt in i have herd it does but never seen it so i can't confirm that one so i hope this helps a bit.
-------------------- bread to be force fed
Jul 4 2010, 07:52 PM
Post
#4
![]() New Member ![]() ![]() Group: Members Posts: 15 Joined: 4-January 10 From: west auckland n.z. Member No.: 10048 Last Active: 31st August 2010 - 03:57 PM |
hey mate, ive just done this conversion and tried to do rb mounts. yes the ca engine mounts bolted up to factory ke crossmember with rb mounts, BUT the engine sump was about 60mm off the crossmember. so we welded custom mounts onto the ke crossmember to suit to get engine lower.
Jul 4 2010, 10:26 PM
Post
#5
![]() ^^^is poor and thats why he drives a rolla ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 1311 Joined: 4-December 08 From: At your house drinking your beer Member No.: 7244 Last Active: Today, 10:52 AM |
hey mate, ive just done this conversion and tried to do rb mounts. yes the ca engine mounts bolted up to factory ke crossmember with rb mounts, BUT the engine sump was about 60mm off the crossmember. so we welded custom mounts onto the ke crossmember to suit to get engine lower. what is this said mod in? And how much lower did you get the motor in the car? -------------------- THE BLACK PEARL
PSIFED36 The death of a 4K is in other words as spectacular as the experience of accelerating a 4K car itself :P QUOTE ("Rollin - boostedfalon.net") You need to learn about the chain of command my friend. The chain of command is the chain you beat c*nts with until they figure out who's in command :) |
Jul 4 2010, 11:12 PM
Post
#6
![]() Regular Poster (Caption Editable Now) ![]() ![]() ![]() Group: Regular Member Posts: 77 Joined: 22-October 07 From: Perth Member No.: 4551 Last Active: Yesterday, 11:33 PM |
hey all, i was just wondering if anyone has done this personaly because i have heard alot but have not seen any finished projects. i am looking at doing this myself ( only because it seems easy ) but i don't want to rip my 4k out for nothing thanks in advance Hi mate, Mounting the engine is probably the easiest part of any engine conversion, so don't limit your choice because you think it might be hard to put in something else that may require custom mounts. Its all the other things that come with doing an engine conversion that will give you the shits. But its all fun |
Jul 5 2010, 03:26 AM
Post
#7
i know it's not a ca18 and the 4k mount's been cut down a bit but you can see the rb20 mount slides into the 4k one you have to grind the little tab off the rb20 one and grind the 4k side a little, as for a straight bolt in i have herd it does but never seen it so i can't confirm that one so i hope this helps a bit. ![]() my mate just got a rb20 with mounts that don't have that pin don't know why and for a street car is 60mm off that bad? i was just hoping for no welding/cutting involved |
Jul 5 2010, 05:40 AM
Post
#8
![]() huckin whips for the bitches ![]() ![]() ![]() ![]() Group: Regular Member Posts: 245 Joined: 28-March 09 From: tin can bay QLD Member No.: 7974 Last Active: Today, 09:37 AM |
u want to do a conversion and don't want to weld or cut
-------------------- 4k FOREVER
rides: ke70(black knight) 323 20b (highway death car ) jackaroo (towcar) |
Jul 5 2010, 08:07 AM
Post
#9
![]() Well Known Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 1659 Joined: 25-May 09 From: Epping Melbourne Member No.: 8435 Last Active: Yesterday, 09:59 PM Real Name: Evan. |
must be school holidays agian......
-------------------- for ke30/55 parts PM ME!
Jul 5 2010, 10:21 AM
Post
#10
Jul 5 2010, 12:51 PM
Post
#11
Thats pretty cool man so thats just the stock k crossmember mounts cut off and positioned where you want wicked, lucky you can weld haha,
Jul 5 2010, 01:40 PM
Post
#12
Thats pretty cool man so thats just the stock k crossmember mounts cut off and positioned where you want wicked, lucky you can weld haha, yep prety much, steering rack is quite close, also i would recommend if you wanted it to be a street car to do rb box on the ca bellhousing for much better shifter position and less chopping of the car. |
Jul 5 2010, 06:25 PM
Post
#13
yep prety much, steering rack is quite close, also i would recommend if you wanted it to be a street car to do rb box on the ca bellhousing for much better shifter position and less chopping of the car. yeah mine is gonna be a street car but i'm using the ca crossmember, i was thinking about rb box with a ca front -------------------- THE BLACK PEARL
Aug 12 2010, 12:33 AM
Post
#14
![]() robbo ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 389 Joined: 5-September 05 From: Brisbane Member No.: 795 Last Active: 23rd August 2010 - 11:26 PM |
ca18 crossmemeber wont work u will need to fabricate one using the ca rubber gearbox mount very easy using some 25-30mm box section and some flat bar.
-------------------- CA18det ke35 hardtop- 301rwhp on 14.5psi on Pump fuel and 12.41@115mph
Its here: http://www.rollaclub.com/board/index.php?s...mp;#entry139937 |
Aug 12 2010, 12:34 AM
Post
#15
what model you putting the ca in by the way?
Lo-Fi Version | SEO by MinervaSEO | Time is now: 9th September 2010 - 12:56 PM |
Im4eversmart | ||
