Jul 30 2010, 12:00 AM
Post
#1
New Member ![]() ![]() Group: Members Posts: 32 Joined: 18-March 09 From: Melton, Vic 3337 Member No.: 7913 Last Active: 1st September 2010 - 03:56 PM |
Hey guys,
I'm dismantling the car for wrecking and I have taken off the gear lever (its a manual), got all the bolts off the bell housing to engine, removed the tailshaft, disconnected all the associated wires connected to the box along with cables and such, but I can't for the life of me work out how to get the box to come off. I've shaken, pulled and shaken together, also jacking up the box from the side. I'm pretty sure its in neutral, if that matters, and I vaguely remember having a similar issue when I was trying to remove my cars original 4 speed box and the one from the donor car 4 odd years ago. The whole engine is pretty much ready to come out, as I'd previously unbolted that over a week ago and had grinded off the nose cone/radiator support to make it easy to take out the engine without smashing a good windscreen. Anyone know what the problem is and any tips? I'll probably end up putting a couple of bolts onto bell housing/engine and dragging the engine hoist out tomorrow to take whole thing out. Cheers Jesse |
Jul 30 2010, 09:17 AM
Post
#2
![]() Known Member ![]() ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 884 Joined: 25-January 09 From: Orange... near Bathurst! Member No.: 7544 Last Active: Yesterday, 10:42 PM |
Any gap at all between the box and motor? 5mm??
Starter off? Flywheel blanking plate off? I assume you have all the bolts out and its just rusted into the clutch/flywheel a little. Take both out as a unit and take a look then. -------------------- |
Jul 30 2010, 09:21 AM
Post
#3
Known Member ![]() ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 641 Joined: 22-November 06 Member No.: 2532 Last Active: Today, 01:38 PM |
Take both out as a unit and take a look then. yeah put 2 bell housing bolts back in and take engine/gearbox out as one unit. though if your set on getting the gbox out, you may need to apply some wedging action between the gearbox and the engine. there is a split down the bottom i think (to let oil out) so you can get a decent sized screwdriver in there. it should be pretty lose though, so if the engine is still bolted in, grab hold of the shifter end of your gearbox and give it a good wiggle, should come lose! the thing that will be holding you back will either be the spline in the clutch disc, or the input shaft in the crank spigot bearing. -------------------- ![]() |
Jul 30 2010, 12:27 PM
Post
#4
![]() Known Member ![]() ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 775 Joined: 23-February 05 From: brisbane Member No.: 383 Last Active: Today, 10:43 AM |
+1 on the starter motor
-------------------- corolla in progress...
Jul 30 2010, 03:05 PM
Post
#5
![]() Hachi Ni ![]() Group: Donor Posts: 4156 Joined: 19-March 06 From: Ipswich, Qld Member No.: 1373 Last Active: Today, 01:26 PM Real Name: Trev |
Bolt the clutch slave back on and push the clutch in, this will try to push the box away before the pressure plate moves
Jul 30 2010, 03:08 PM
Post
#6
Bolt the clutch slave back on and push the clutch in, this will try to push the box away before the pressure plate moves that is an incredibly brilliant suggestion!! -------------------- ![]() |
Jul 30 2010, 03:10 PM
Post
#7
I know for a fact that it works
Jul 30 2010, 10:13 PM
Post
#8
I've taken out an engine from my HZ holden van before, but the 4kc engine doesn't have very many places to put large bolts to hoist up, so I just put a couple in the bell housing and looped a thick bike lock around the hook ontop of the engine a couple of times. Engine was a pain in the butt to take out compared to the HZ.
But got it out nevertheless. I was still struggling to get the box off even after I had the engine removed, the two metal dowels were fairly tight, no rust, but alot of grease. Eventually got it off by wriggling it up and down. Then gave the T50 a good clean, came up pretty good too. Thanks for the advice guys. |
Jul 30 2010, 11:24 PM
Post
#9
Pics of the engine and gear box
which I removed from the car today. I had to cut the exhaust off near the engine, as its bolts were very rusted. This post has been edited by ecoimpact: Jul 30 2010, 11:26 PM |
Jul 31 2010, 01:08 AM
Post
#10
Box is a K50.
Jul 31 2010, 06:19 PM
Post
#11
Lo-Fi Version | SEO by MinervaSEO | Time is now: 9th September 2010 - 01:40 PM |
Im4eversmart | ||
