All Activity
- Yesterday
I have some of the Ranex Rustbuster, but my googling indicates it doesn't leave a zinc layer after it's done the rust conversion, so it's probably not suitable for leaving on for any length of time. KBS ship straight from their website too, might be worth cutting out the eBay middleman. They also have a Por-15 style primer/sealer I'm going to give a try.
- Last week
Hi John, Sorry, I went & looked again, & You are right that Bunnings do not seem to stock it. My error. When I took a look again the one Bunnings market, looks very similar, in a yellow & read container, & is called Ranex RUSTBUSTER.
I got the 4 litre bottle on ebay. I've previously bought it in small bottle from an automotive paint supply place but had a couple of ordinary experiences there so went online. My bonnet had had a serious bird shit attack and the rust webs were all over it. I'v rubbed those spots down to metal and treated with KBS and it has been like that for more than two years. When ready for paint i'll strip the whole thing
Thank you everyone. I couldn't find it on the Bunnings site, but I'll keep looking. I've got Ranex Rustbuster and Evapo-Rust, but you can never have too many chemicals. I've got some Upol #2 on order.
Thanks Pete ! I must have been living under a rock; as I've never come across KBS Rust Blast previously. Sounds like good stuff. It's even available at Bunnings, apparently. This is what Google says about it . . . Thank You for that pointer. I'll try it out very shortly, as my bonnet has a few sections that need treatment. Cheers Banjo
This is mine more than a year after stripping all the paint off with stripper and a flap wheel where necessary. I then treated the whole area with KBS rust last. Any areas that showed any sign of colour where then treated again. The coating Iโll wash/ neutralise when I spray epoxy sealer hopefully soon
You can check out cashforcarsadelaide for good wreckers in Adelaide that deal with rolla, Toyota, and other car bits. 4.1-mini
AdelaideAutoRemovalsNet joined the community
Get some Upol #2 weld-through primer in copper, we use it all the time on race car fabrication. Its a lot more expensive than the zinc, but they are rubbish to weld through, its just like welding galv pipe. I'd use paint stripper to start with, get all the paint off as there will be little rust-worm trails under paint that look fine from the outside. We took the driver's-side top surfaces back like this, even if the paint looked OK for 99%, underneath were little rust trails heading off in all directions. I figure it spent its life in a carport up against a wall on the passenger's side, so the drivers side was weathered.
Thanks Banjo, I have a few Rotisserie videos in my queue and I'll add those. In this case I'm focusing on the bonnet for a few reasons. 1. They are in demand, so if my build goes nowhere they still have value. 2. The bonnet is in my garage but the rest of the car is 500km away. The bonnet (and guard) are from Captain Kerolla, so their condition is not reflective of the rest of the vehicle. I'm going to school on these parts, and I can get them up on the bench under my workshop heater. John
Glad You are into it ! Hope is addictive, & not too despressing. I'd really be concentrating on the structural bits first, as they are the most important, after all. Shame to do all the surface & visual pieces, & then find later on, that there is a structural section, beyond repair, & that all the visual; non structural clean up, was in vain. A simple rotisserie would be good, so it is easy on your back. No fun working upside down, when You get to the underfloor area. Metal Rotisserie Wooden Rotisserie Cheers Banjo
Hi Everyone I'm still working on my bonnet but I feel like I'm chasing my tail a bit with the rust removal. I've de-skinned the bonnet to get at the surprises underneath. Lots of pinholes I couldn't see from the top. I've been using a combination of stripper disks to remove paint and Evapo-rust to get in to the nooks and crannies. This works (pitting and blow throughs expected) but because I'm just doing an hour here and there I feel like the surface rust is back as fast as I remove it. Should I be hitting sections with a weld through primer as I go? Can I leave paint in place where it's clear the metal beneath is good? Will that impact the final finish in a big way? Thanks for any advice.
- Earlier
ejulikram3 joined the community
Sure, we have it hosted here- https://www.dropbox.com/scl/fi/kxtqr769ojtetah/downloadfile.jpg?rlkey=ulck2pyqn6u8nd163h0awrj7w&e=1&dl=0
Agung1034 started following KE70 electric wire map
Can i get one too please?
Agung1034 joined the community
ELECTRIC FUEL PUMP WITH SAFETY PRESSURE SWITCH
corollaart replied to knibusu's topic in KE70 Technical Questions
Yes Kieth ,ask me how i no๐ -
Ok cheers, thanks mate
Hi Tony not sure about the dellow bellhosings ,but K-T housing it was better with TA22 because of the more forward shifter position. The ae71 and ae86 T50 s had there shifter towards the back of the extension housing. Hope this helps a little rob
Tony&CJ started following Celica 5 speed
Hey guys, 30 odd years ago I put a Celica 5 speed box in my 3K KE20, using a Dellow bellhousing. However I canโt recall what model box it was as I bought it second hand with the adapter housing. Does anyone know what it may have been or what to use for a similar setup?
Hi Tony, My guess is; that now You will want to calculate the new "compression ratio", of your 60 thou bored engine. This is a little more complicated, depending on whether you have flat top pistons; or pistons with domed or concave top faces. This calculation, should also take into account the thickness of the head gasket, once torqued down, to be truly accurate. Here is a variety of sites tackling this question, if Your interest requires this information. How to Calculate the Compression Ratio Obviously, if you bore the engine, & leave the combustion area in the head untouched; the compression ratio, will increase. Question is; by how much ? This link here on Rollaclub, from over a decade ago, might help ? https://www.rollaclub.com/board/topic/69246-4k-engines/ Cheers Banjo
I appreciate your response and info, much appreciated mate, cheers
Banjo started following Displacement for 4K
The volume of a single cylinder is Pi x r squared x the stroke. 22/7 x bore/2 x bore/2 x stroke. For a standard 4K engine, the bore is 75mm & the stroke is 73mm Substituting these into the above equation give (22/7) x (75/2) x (75/2) x 73 = 3.1429 x 37.5 x 37.5 x 73 = 322638.33 cu mm Divide that by 1000 to obtain cubic centimeters & you obtain 322.64 cu cm. That is for one cylinder. To calculate that for 4 cylinders, simple multiple by four. 322.64 x 4 = 1290.56 cc, which is what the good book says the capacity is for a standard 4K engine. Now simply add 1.524mm (60 thou) to the bore dimension, & recalculate. 3.1429 x (75.00+ 1.524)/2 x (75 +1.524)/2 x 73 = 3.1429 x 38.26 x 38.26 x 73 = 335.85 cu cm Multiple that by 4 & you get a new volume of 1343.4 cc. Subtract the original standard volume = 1343.40 - 1290.56 = 52.84 cc. or an extra 13.21 cc to each cylinder's swept bore capacity. Yep, basically, the same as Simons calc. Cheers Banjo
75mm stock bore, + 1.5mm (60 thou). 73mm stroke. That's all you need to know to punch into a displacement calculator ๐
Tony&CJ started following Displacement for 4K
Can any propeller heads out there tell me the displacement of a 4K-C with 060 oversize pistons?
Banjo replied to knibusu's topic in KE70 Technical Questions
I'm intrigued now; as to why all three (3) brand new mechanical fuel pumps, mechanically failed; all with damaged diaphrams, in a short period of time; when You had utilised the spacer block to mount them off the engine block mounting point ? The only thing I could suggest; was that the curved arm on the aftermarket ones, was a different shape or profile, to the Toyota original supplied & fitted pump ? My KE30 with a 4K-U engine has been running a mechanical pump for 20 years, I've owned it, without issues. They are not real good at drawing/sucking, without priming; but once that line has got fuel in it, they never stop or fail; from my experience. Got me beat ! However, I applaud your determination to fit a good electric fuel pump, in the boot area, close to petrol tank. It is the way to go. P.S. In a petrol / carby engine, the fuel pump is one item, you can actually drive, without using one at all. Many years ago, in an olde English car, the S.U. fuel pump failed, in the middle of no where. A small plastic jerry can, was roped to the roof rack, & a plastic tube run from said plastic jerry can, to the carby fuel inlet. A quick suck on the tube to get the fuel running down the plastic hose, & we drove all the way from Brisbane to Sydney, without so much as a hiccup ! I think it is referred to, as "gravity feed". True story. Cheers Banjo -
knibusu replied to knibusu's topic in KE70 Technical Questions
Yeah every single pump I got came with the spacer and two gaskets. I keep the spacer and gaskets as spares now ๐, but yeah I don't know, I'm gonna try the electric fuel pump setup and see how I go. Also I had a look at my ignition switch and tested each terminal with a multimeter to test for 12V source I am a bit of a visual learner so looking at the wiring diagram I understand it a little bit but actually seeing the circuit and testing gave me a better understanding Ill let you guys now how I go with the installation and keep you posted. ๐ค. I also have a immobiliser in my and the previous owner ran it off ST2 seeing that and testing voltage when immobiliser is on and off was interesting to.
