4agze Into Ae71
Phat535
what else apart from motor and computer are needed to do the conversion?
I assume they would have a mechanical fuel pump on the side of the motor?
can I just run an external pump in it's place or will I need to also fit a pick up pump in the tank?
Is the fuel line thick enough? Or will I need to change it
Those of you that have done the conversion before, what did you use as a fuel return line from the fuel rail to the tank? steel tubing? or just a length of rubber hose?
Any thing else I need?
Link to comment
Share on other sites
why will I have trouble with a mod plate?
You only need to upgrade brakes on cars before 1971 when doing an engine conversion. And even then there has to be a certain amount of increase in the engine displacement before an upgraded is needed.
As for the clutch concern....what car should I ask for a clutch for?
A 4AGZE clutch flywheel apparently won't fit into the T50 bellhousing I was told
A flywheel from a 4AGE is slightly smaller isn't it? were there any aus delivered cars with a RWD 4AGE so I can just go buy a clutch/flywheel for that?
Dave
Link to comment
  • 2 months later...
