Leaderboard
Popular Content
Showing content with the highest reputation on 05/13/18 in all areas
  1. Man buys shocks. Man gets told precisely how to change shocks. Man decides the work to change shocks the simplest and only way is 'fluffing' around. Man needs instant gratification. Man wants a quicker way that the actual simplest way to complete the task. Man needs to follow instructions. Man needs to realise it takes about 4 extra minutes of work from the state of things in the above photo to complete the job. Man should enjoy the benefit of new shocks sometime in the next ten to twelve minutes if he can find a big pipe wrench and the will to do it.
  2. 1 point
    Haha! That's where I test and tune! It actually spat the (water heated) intake manifold gasket along there last month. Wasn't happy. I prefer dry gaskets but I had been persuaded by an aircraft mechanic pal to use goop on the first gasket. No good. So the new gasket went on dry and I'll nip up the nuts in a few weeks While I had the carbies off I realised the pump rod was jammed on one of them, making it impossible to tune. All sorted now and it's going heaps better. Still not 100% on a 1500rpm clutch dump but certainly driveable. I might swap around some pump bleed jets to narrow it down. I think the old 15" tyres are a bit hard and maybe even flat spotted from sitting as I've got a bit of a vibration over 100. So I haven't taken it very far. Still ironing out the niggles to be confident taking it on a road trip but it's done around 1100km now. Fitted a Cusco strut tower brace which probably doesn't do much, but I always wanted one. $200 delivered from Japan in 3 business days which was fairly reasonable I thought! Next project is in progress. I've dug up the entire backyard for a driveway. That should keep the mud out of the shed and off the car.
  3. Hello there new to the forum i have got a 1953 morris minor split screen got a 4k motor with 5 speed have recently put ke70 hubs and calipers on the front i have recently got a 5k which I'm going to rebuild and replace the 4k i have also own a 1971 datsun 1200 ute which i just finish restored late last year i put in a A14 injected motor with air con
  4. Great Projects. we're gonna need much higher quality photos of that dato ute! i'd love one of them.
  5. All Corollas look great with generous ground clearance.
