Ok, this isnt another 'I'm thinking of going down this path' thread..
Basicly, iv got a 84 rolla (I think its a KE71) and I plan to strip it to bits and track it.
I'm going to strip pretty much everything, aside from the drive-train. I'm going to turbo-charge the stock motor and use that untill it dies.
This isnt a daily drive, so it can sit around for as long as I need :)
Just wanted a few pointers for the build in certain areas..
I will be running a blow through setup on the stock carby (if possible, may have to get one from a 2.5L+ motor), and will have to encase it to prevent fuel going out the bowl.
The turbo Ill use is a CT9 from a starlet GT (1.3L turbo) stock is 7psi on that car, and thats more than enough for what I want.
This will be running through a factory XR6 Turbo inter-cooler (it only has about 1-3psi pressure loss on the falcon, so little to none on this car)
My concerns are about the fuel pump, and where to tap the oil lines..
Whats the standard mechanical pump rated at, 5psi? meaning I can't run my desired 7-8psi.
Ill chuck in some standard WRX seats, not sure what todo with the dash.. its just extra weight, but less work than making a new one.
I will definitely need to address suspension and possibly the rear diff.. I could either weld up the stocker, or somehow find a LSD (or just swap out the diff entirely for like a hilux diff)
Anybody want to chime in here?
Thanks guys
