hay i did some reading just now this is only basic
but it is realy helpful http://www.mazdarotary.net/turbo.htm << good read there
probs need more help on how to retard/advance ignition
and having to upgrade fuel system
and what i am likeing the sounds of is suck though
what is done with the issue of a bov well allowing the turbo to spool when not under engine revs if that makes sence
do you just let it suck on the closed carb throttle could i make say something behind the carb before the turbo linked to the throttle cable thing on the carb that say opens a a bypass valve on a secondary small intake pipe or somthing on the tubing before the turbo after the carb which is opened when you take your foot of the gas would this be ok as it also when it sucks air from the brypas would there be air fuel mixture issues as the carb would be letting less fuel into the cylinders and the turbo pushing a more air rich mixture on decelaration could this be a major issue :hmm:
would changing to a bigger down drought webber carb help this setup or would you have to rejet it
i also added a diagram of my idea
edited diagram
