4M Straight 6, Easy To Work On?
Has anyone here had much experience with the Toyota 4M motors, carby version? Are they as easy to work on as say, a Corolla 3k/4k motor? I am somewhat looking for Cressida or Crown which runs a 4M, but I don't want to get something that is a nightmare to work on, particularly seeing as my mechanical knowledge goes no further than a basic service on the holden V6's, and the 4AGE motor.
Vs Ute
A 2.25 was better than a 2.5 around town in my VR, even frequent passengers said it felt more torquey. It is worth noting that VR's don't run ecotecs but have the same capacity motor, so results on a VS should be similar, unless you put some money into the engine, and made it need a 2.5 to breathe well. Where are you going to mount the 3rd reverse light? Why not just put brighter globes (within reason) in the factory reverse light spots?
Car Storage
Sadly none I know have spare undercover area, any present rust on the car would love the exposure to rain. I like the sound of that option, I may ask around and see if any local places have a relaxed stance toward clients working on their cars.
Ae92 Seca Help Please?
Welcome to rollaclub! You could either sell your AE92 and buy an AE93, which has the 4AGE motor, and the close ratio C52 gearbox, which is noticeably zippier than the 4AFC c50 combo you have. Or buy a crashed AE93 and swap the running gear in.
Car Storage
I am toying the idea of purchasing another vehicle in the coming months, however I do not have sufficient space to keep it 'off street' at my current residence, so I would be looking to store it offsite. Off street parking/storage is a must. Ideally, I would want to hire a garage/shed so I can keep the car safe from the elements, and from unsavory people, hiring a parking space in a parking lot may also work, or even a storage facility, but I am not really keen on the latter two as working on the car would either be very difficult, or even prohibited. I assume a few of you have cars stored off your residence, what sort of 'storage' do you use, what sort of monthly rates do you pay, and how did you end up finding the place?
Vs Ute
With commodore catbacks, all premade 2.5" ones are pretty much the same, in that they use straight through mufflers, choice seems to come down to what tone you want. Redback seems to be the common choice, depending on who you talk to, Lukey is either slightly deeper or slightly raspy, best bet is to ask around for audio clips, or even ask people to take for a spin in their car with an aftermarket exhaust. If you will be going custom made, you have the pick of a 2.25" stright through system to maintain low end torque and driveability, with marginal sacrifice, if any in the top end (an exhaust fitter I spoke too reckons a 2.25" striaght through on a V6 commodore will easily outflow what the motor can put out in terms of airflow) or a 2.5" to go a bit louder, and possibly have a bit of top end, also is a good choice if you plan to cam the motor later on. The bare minimum I would recommend is a centre straight through offset muffler, and a hotdog at the rear to minimise drone, you could even run a straight through muffler at the back too to reduce drone further and make the exhaust quiet until you sink the boot into it. Pick mandrel bends if you want better flow, or press bends to minimise cost.
The Joely-Rolla -- Ke30 2-Door Project.
The rust doesn't look too bad, you can easily find worse on other K series rollas. Are you just going to use rust converter and filler, or are you going to go the hard yards, cut out the old metal and weld fresh metal in? I also hear that silicone absorbs or attracts water, so that is also another rust promoting property of it.
Jordains 69 Rolla.
SSR Mesh all around would look the business, I'd personally leave the centres as is and have the lips polished, to contrast the white of the body, car is looking great by the way, nice work!
Newbie, Looking For Advice (1988 Ae82)
Actually, I recall an issue you may have when you try to upgrade handling. The 3 point strut brace has the midpoint bolt in on the twincam AE82 models, where the compliance plate is on non twincam models. Have a look at your car to see if this is the case. You may be better off just using this car to learn proper maintenance and good driving technique, then if funds allow, buy a average or worse condition twincam and slowly fix that up, then retire the one you have now when the twincam model is ready. You could even have a look at the one Ethos is selling and decide if the rust can be fixed. You will never get a 4AC model to go or handle as well as a twincam unless BIG money is spent.
+1 for focusing on handling. Feel free to mod the 4AC if you really want to stick with it, but you will be spending a noticeable sum of money, and still wont get the performance of a 4age. If this is your first car, learn how to service it, then try out more intensive stuff such as replacing worn suspension parts and the like. These cars are relatively simple to work on, and parts are plentiful.
Doogs' Ke20 - Lke020
I see, I would probably want to redo at least my roof and guards one day, may even do the whole car to get it looking nice overall. Would 400 grit be too harsh to start off with? I've tried 1200 grit, wet, but it wont get rid of the stubborn bits of lacquer, or do i just need to spend more time on the wheels with the 1200 grit?
Toyota Car Club Meeting
Sounds good. Where do attendees typically park?
1967 Toyota Crown Ms47 Wagon
Nice find, cars like these deserve to be saved. Actually looks decent after a cut and polish, it will look great once it is complete!
Subaru_Kid's Ae82 Tin Can - Parting Out
April Fools was last month. The GSS snap of the tincan looks overrated, should print that out and frame it haha. Edit: lol strong typo, meant to say really great , or sometihng along those lines, instead of overrated, should have a coffee before jumping on the forums in the evening :S
Ke30 Sr20 - Finally Finished (98%)
Nice little beast you got there, should be a bit of sleeper once you whack on a grille to hide the intercooler.
Onikage
