Everything posted by JasonKE55
Ke30-55 Members Page.
Name: Jason Car: 1979 KE55SE Motor & Driveline: S13 SR20DE + SR/RB 5 Speed Suspension & Brakes: Standards for now Wheels & Tyres: Standard Interior: New carpets, resprayed whole dash. Modified centre console to suit 5 speed. (was auto) Body: Standard (Sleeper!!!) Other:
Which Clutch Master To Use In Ke55 Sr20 Conversion?
Hey fellas, wondering what you guys have used as a clutch master cylinder in an Sr conversion in ke55. It's a pretty tight space so I can't use the standard Sr clutch master as it will stick out way past the intake mani. Have heard about the ta22 but not sure dimensions and compatibility. Cheers
- Sr20 Clutch Setup In Ke55
Hey fellas, I'm about to install my clutch master in the KE55. I purchased an S13 clutch master and going to be mounting to standard ke55 manual pedal. Does anybody know the best way of measuring and positioning or has anybody done this before and have a drill template?? Cheers
Ke55 Clutch Cable To Sr20De Trans
Hey fellas, Another question about me old conversion. Trying to figure out the best way to run a clutch cable to my sr trans. Would you guys suggest buying standard clutch cable and modifying or any other ideas from the guys who have done it before?? Cheers
Sr20 Into Ke55 Fuel System
Cheers caibs
Probably going with the Datsun 1600 3 row radiator. Same in/out configuration. Slighly wider than standard but height is good. Chuck a thermo + shroud on and good to go!! ;)
Sr20De In Ke55 Radiator
That looks great, what about the radiator cap, does it clear the bonnet??
Cheers parrot. I just found a Datsun 1600 radiator that should fit. Ports are on right sides too
Inlet should be on left looking at from drivers seat. Outlet on right. Do u know the standard ke55 radiator outside dimensions??
Cheers mate
Altezzaclub, I just put up a post about radiators. I have no idea yet. The s13 radiator could fit if i set it back but are there any other options?
Hi Fellas, I've been trying to figure out which radiator will fit in my KE55 with Sr20de. Measurements for s13 radiator if i set it hard up against the front would be too high for bonnet to close. Are there any alternatives with correct inlet/outlet orientation that will fit or should i try and fit the s13 radiator further back off the rail and put thermos on front?? What have you guys done. Cheers
Thanks guys, so basically increase feed and return lines and it's up to me whether i go external or in-tank pump. Its an Sr20DE btw.
Hey guys, I'm in the middle doing an Sr conversion into my ke55 and I'm trying to figure out what's best for fuel system. Whether to use inline or in tank fuel pump. Which one you guys recommend. Also what size fuel line for feed and return. Cheers
