Everything posted by sliesh
- Sold
Weird Email From Rollaclub Sayn My Comp Has Virus?
hey every one, has anyone else been getn an email in their rollaclub messages from a rolla club memeber sayn that theys "detected" virus activity coming from your computer then says to see the report "insert link" , its a bit sus if you ask me, so if any of you get this i wldnt click the link just to beon the safe side, you never know if these things are real or not. Sliesh
Yes Yes More Ke30 4age Conversion Questions
a) just use a std manual pedal box and adjust the clutch arm to the other way around have to show u some how Radiator: What radiator can i use that will have the outlets on the same side ? Or will i have to fork out $300+ for one from ebay ? i got a quote to put the radiator out let on the other side quote was $50 as there only put in by led so make a nother hole put it in and weld it and put a plate over the other hole thats what i was goin to so quote from pro's was about $50 surg tang and 2 pumps about $300 Tailshaft: Will the stock one fit my T50? if you use a celica t50 you wont have to change it but you will need ane 4a a jdm ot a adm bell housing
Sold
spare motor is a ca18de with auto on it has loom ecu etc came out an imported front end with only 60,000klms on it only reason to keep it is i had it for a spare for my silvia but i wont need it as the silvia is strong and runs sweet cheers.... as for leaks there are no leaks i know of and i don't treat my car like shit so i don't know if it open wheels etc cheers...
Sold
bump bought a ute now so car no longer needed cheers...
Sold
hey if you read up there a bit more it says I'm in adelaide 3 times cheers....
- Sold
Ke55 Diff Offset Into Ke 25
sorry to but in but if you use ke20 diff center is that weaker than a ke55 center? do you think the diff will blow or the axles will snap? in a case of burnouts or playful driving lol? I'm just curious sorry if i have butted in to the convosation cheers....
Serious Opinions Please
deff worth $1600+ but all depends on the buyer'
Brake Upgrade For Ke20
i 2nd that has any one done any thing that just bolts in with out cutting things like struts or rose buding there lca's (cos of posative camber)? i heard people swap there ke20 brakes for ke30 rotors/calipers but probably wouldnt make much difference' ? also does any one know of a bigger master cylinders to use with out them ramming in to the inlet manifold(4age in ke20) ? any help much apreciated cheers.... :y:
Ke30ebay, Body Kit And All
sorry :jamie:
BAH HAHA HAHA HAHA ( falls over ) i don't think any one will own up to this now lol i saw one in adelaide like this yellow aswell look's almost exactly the same LOL
$50 Paint Job
hey guys I'm posotive it would work out all good he aplied alot of coats and after using 1400 grit sandpaper and a polisher or just wet dry' a thick enough coat of paint will work out sweet the only thing is the paint would be $50 you still need sand paper and thats about $40 and the brushes $20, and the paint does it need the primer? will it stick properly'
Suggestions For No. Plate
i like the RIP-POP plates if you get pulled over you could say its your pop's old car and he pased away ( acting sad lol ) lmao
$500 Budget... What To Spend
hey lol sound like fun go find some ford au springs cut them for the rear? and cut the stock front springs ? upull it in adelaide sells springs for $11 each? with the left over money find a cheap webber if some one is nice could cost $50 and some extractors for $50-$100 ish? with the remainding money do the spark plugs and leads and rest of the money in av gas lol jj
4age Distrubutor Caps And Leads
hey i have a small port and I'm not sure what motor the leads came off of, but i wanted to get some thicker leads for more power' what do you guys think i should do? thanks
hey evey one topic if for my 4age 16V i just bought some 2nd hand 8mm leads in good condition and was puting them on my dizzy and they seem to big :P can i use a diferent dizzy cap, are they interchangeable? or do i need a diferent dizzy? any help will be great full also if any one has a spare 16v dizzy cap to suit the 8mm leads imd be interested? I'm located near blackwood :hmm: SA cheers....
Ke 20 4age Engine Mounts
sounds like a plan pm'd :D
hey does any one know where in SA you could get ke 20 to 4age engine mount made (engineered aswell?) has any one got some made and can give me a phone number of of a fabricator/engineer? ' also if any one has got some laying around i would be interested cheers...... i live down south near blackwood pm me cheers...
Ra60 Brake Upgrade
i put the ra 60 conversion in my car (ke55 coupe) works sweet i was so happy till some one pointed out my mad positive camber issue, i have to do somethin with the control arms now and you need 14'' wheels to get over the calipers, obviously but thought it may help w58 are worth a bit but to most rollaclub people its not worth the $700 bellhousings to convert the w to k or even t series bell housings best to sell it to a ( holden person ) ?
4age Into Ke30.
hey lol I'm in the same position I'm gettin a 4age built for a boat motor lol 120 kw :yes: for $500 but the things you have to think of is cost of a gear box and you will have to do all the mounts yourself or paysome one to do them i worked it out to be about $1000 to do mine on the cheap and once the motors in there you will need to do brakes, diff and suspension unless you arnt going to comply it. hope this helps (some how) lol ....
4age Into Ke30.
