Everything posted by irokin
The Off-Topic Thread
There are a lot of restrictions in F1 but there is still HEAPS of innovation. Restriction -> Innovation -> Restriction -> Innovation. That's pretty much how the F1 cycle goes. Probably the most notable at the moment is the use of the Coanda effect to try and recover some of the downforce lost from the outlawing of blown diffusers (See McLaren, Redbull). Other innovations of note are Saubers use of a slot through the nose of the car to keep the airflow attached behind the step nose. Mercedes double DRS system which stalls out the front wing when DRS (drag reduction system) is activated. I haven't seen it so much this year but last year teams were using a very clever layup of carbon fibre that allowed the wings to flex at high speed (to reduce drag) but maintained enough stiffness in the right load directions to allow them to pass the mandated load testing. Redbull last year were using a clever pivot system that exploited flaws in the testing jig to pass the loading tests on the plank (wooden section that runs along the bottom of the car). That allowed them to run the car closer to the ground with a high rake angle to improve downforce without wearing away the plank below the minimum depth requirement. But you have to get pretty invested in the sport to follow the changes and understand what it means for the cars performance. Scarbs blogs always good for a read and covers a lot of what I've mentioned: http://scarbsf1.wordpress.com/ WTCC has some pretty good racing: Link
Here's the story. Allegedly a technical ʞ©$ɟ up but who knows.
Oh don't worry Dave. I have plenty of ways to avoid watching Ten's dismal attempts at "coverage" ;) Sadly the Sky coverage can be pretty bad (sappy/tacky/derpy/wrong) too. I cherish the races which have full BBC coverage. Then again, I heard Ch7 went to ads with 2 laps to go in the supertaxis and missed the end of the race. Maybe it's just Motorsport coverage in general in Australia is pathetic.
Oh now that's a bit low. This is by far the most competitive season of F1 in years. 4 different race winners from 4 different teams in the 4 races so far. Sure beats the conga line supertaxis.
People raging at Ten over the shithouse F1 coverage: http://twitter.com/#!/search/tensporttv Hilarious.
Cusco Camber Tops On Standard Ke30 Struts
Space. There just isn't enough room to move the strut when there's a massive coil spring taking up most of the strut tower.
Yea but did it have good indicators?
The Silvia
BM44 master cylinder and front brakes are on. I've change brake fluid over to Tilton's TSR-1 seen as I need to do a full flush anyway. It was a decision between that and Castrol SRF but seen as SRF comes in 1L bottles and Tilton comes in 250mL bottles I went with the Tilton stuff as it's less fluid wasted. Plus it's slightly cheaper. Found out my clutch master is leaking so I'll order a replacement master, slave and change out the hardline spaghetti for a braided one. Bit of a shitty pic but here you go:
Post-Update Bugs
Did a bit more work on the tagging, hopefully should work for everyone now.
The Mtb Thread
Picked up my phaser this morning. Haven't had a chance to do anything properly off the beaten trail but I'm in lurrrveee.
Post-Update Bugs
Ok, finally figured out what the problem was with the new tagging system and the FS areas. That's sorted now so the new system should start to take effect. I'm going to add tags to a couple of pages in the general area to help things along.
The Silvia
Swapped over the front to 5 stud and put on my R33 GTR rims as my Enkei RP-01s are going to a new home. Fitment is awesome, front is like a factory rim though it does rub on full lock. I really don't care though, it's not a drift car. Rears aren't quite as good but should improve once I get the new suspension setup. Needs more camber, less toe and I need to take the helper springs out of the Bilsteins as I can't adjust it any lower. Still have substantially more rake than I want. I'll get a photo tomorrow.
Bug Reports
Fixed. Unfortunately IPS couldn't be arsed fixing that problem. It's a known issue since last year some time. Apparently "Not a bug"... yea if you're an American...
The Silvia
- Bug Reports
The Silvia
Yea sorry, not really a meme (yet) but what the hey. Then tell me, who are you? I am the Master. And these... are my friends.
The Silvia
- The Silvia
- The Silvia
- The Silvia
- The Silvia
- Bug Reports
Fixed the date format, last year available and added some permissions for new calendar features.- Bug Reports
I'll have a look for you tonight Jon. There is a widget sidebar type thing that I can add for the calendar.- From: Dave's Te27 In April Fast Fours And Rotaries. *blush*
Source: Dave's Te27 In April Fast Fours And Rotaries. *blush*- Post-Update Bugs
It tends to count guests multiple times so its a bit more inflated than reality. - The Silvia
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
