350dream
    38
  • Location
    Hobart
350dream's Achievements
  1. also smallports have a roll pin that holds the gear on the shaft that the cam gear drives on and bigports are press on i think.
  2. http://www.nissansilvia.com/forums/index.p...st=90&fcat=
  3. WTB flat front for a ke70. white preferably ....... but will look at anything also have a T18 4 parts and a ae 92csi 4 parts (i think its that... the sport model anyway ) so can trade cheers nicko
  4. yo bruce pm'd
  5. just received a te72 and wondering wether it b a 2t or 3t. its got an electronic ingnition(lucas brand) and the clutch slave is on the drivers side (the t50 in my ae71 is on the passenger side) and all the id tags / plates have been removed. hope someone can help
  6. a cruise down south would suit me also and prolly not 4 a month or so (got defected so waiting 4 mod plate)
  7. sorry tas my mistake
  8. yeah i got 4agze pretty sure its 212mm but idont have bolts and using a ps3 to type sux
  9. Stainless rods??? is spring steel iron free???? not sure bout welding but, if you want to bend spring steel all you have to do is heat it up so it is cherry red all the way through, bend it and let it cool, don't chill it
  10. very easy as far as conversions go. I put a ca18det into a s3 bluebird a few years ago and that bolted up to standard engine mounts and standard gear box and we put 1 into a mates pinny wagon. all it is step 1 unbolting the ca 20 step 2 bolting in the ca18 step 3 wiring (very easy 1 of the plugs had all the wires u needed from memory) step 4 plumbing every thing up (exhaust, heaters ,intercooler, thermo, fuel) step 5 wish u had of put it in a bluebird instead of a heavy pintara.
  11. well it should have markings at the base of the terminals
  12. mind you it did look like this
  13. hey guys just wondering what you think mines is worth also and looks as well fresh 4age with 50mm quad throttles , lumpy cams (not sure of size havent measured) delco ecu remapped TRD copy extractors weld on coilover kit with 6kg springs in the front ,short kyb inserts falcon rear springs and short HQ rear shocks 24mm front selby swaybar 18mm rear selby swaybar 15x8 challengers Autometer air/fuel gauge Speco oil pressure and water temp gauges surge tank VL fuel pump FACET lift pump sorry havent got any pics of the engine bay yet but i will if you like
  14. crank up the amps bout 100- 110 if your using 3.2 electrodes. rutile or low hydrogen 16tc's doesnt really matter but low hydros are better. and not all low hydros are cast iron. just weld around the sungears turn it around and do it again also the closer you can get your earth clamp to what you are welding the better cos you don't want your bearings arcing trying to get earth through to what you are welding.......... if your in the trade you know what i mean hope this helps Nicko
  15. bull SH#T acid will bring them up mickey mouse if its the right type what do you think engine recon place's use to clean cylinder heads and blocks a pressure washer :D :D
