Hokey
    61
Everything posted by Hokey
  1. if you can find a T18 crossmember then that will bolt straight up to your car and the 3t/2t/2tg will bolt right up to it. check out toymods because there is alot of info for these engines. don't forget to search Cheers
  2. 73hp would be nowhere near what most 3k's make . most of the stock ones out there would proabably all be in dire need of a reco and have hardly any power :P
  3. Hokey
    Ke55 Sedan
    cool i have that lying around aswell. i will put the brakes on aswell then. Cheers :P
  4. Hokey
    Ke55 Sedan
    yeh i am upgrading the brakes i think i am putting on a T18 master and i will see if that fits up to the ke30 booster. will tackle it when i come to it. my cousin has quite a few AE71's sitting at his hous aswell so i could try that combination of booster and master. Cheers, Calvin
  5. thats right doesn't matter if you miss by an inch or a mile a miss is still a miss. hmm sounds familiar :cool:
  6. thanks for the reply about the brakes and stuff. in that skid picture it appears your path took you pretty close to that barrier :cool: nice doughies tho
  7. nice boat. what its got in it? you a skier or a wakeboarder?
  8. hey, did you need yo shorten the diff to fit it under there and i am guessing a custom tailshaft? what do you my by camry wet leg strut tubes? did you have to machine your own hubs to get the commodore discs on? Cheers, Calvin
  9. Hokey
    Ke55 Sedan
    ok sounds good. i would like to keep it as far away from the drivers side to clear the master cause i have the PBR MC which is fatter.
  10. Hokey
    Ke55 Sedan
    yeh thanks SJ i have seen that but i was just wondering what rob has done Cheers
  11. easiest just to cut that part of the panel out of another car
  12. Hokey
    Ke55 Sedan
    hey, i am building a car similar to yours. mine will have a 3TG with 1mm OS pistons. just wondering how you mounted the engine. i have heard alot the bolt straight in but are 17mm to one side. are you just using the standard mounts? those flare look really good i will have to get some for my car. Cheers, Calvin
  13. Nikname: Hokey at all my forums Real name: Calvin Hokin Car: KE30 sedan soon to be 2TG/3T hyrbid powered Great site you guys have here cough "better than toymods" cough :D
  14. i Agree
  15. welded diff now to!!! doin doughies last night in an industrial area was sooo much fun. going to the melbourne rally now. chassis rail smassis rail it is fine
  16. Heck yes. But lets wait like, maybe a year or so, so my car will be a bit faster and back together :angrybird: Hahaha. Or not, thats ok. Thanks Troy But has to be before you decide, then build your engine and after i finally finish mine
