December 8, 200619 yr comment_154284 "Previous owner claimed 90hp" When I see the dyno sheet I will believe it. f@$kin LOVE those wheels though *drools* Report
December 8, 200619 yr comment_154288 yeah the dished globes are fuking hot! 90 is a little optimistic but you never know... Report
December 8, 200619 yr comment_154305 I'm quite happy to believe it, when I see it. But it just seems a little high to me. Report
December 8, 200619 yr comment_154327 IMO this guys talking a load of shit. A grouted block means that you're going to have to run either methanol or nitromethane because the high heat of vaporisation point which provides cooling for the engine. The 4A-GE valve springs seem like a step backwards. Generally speaking twincam valve springs are much softer than push rod valve springs because they don't have to push back on a long valve train. His drivetrain claims seem pretty bullshit too. Xanys got roughly that and hes smashing "bog" warners and K50s. Report
December 9, 200619 yr Author comment_154331 IMO this guys talking a load of shit. A grouted block means that you're going to have to run either methanol or nitromethane because the high heat of vaporisation point which provides cooling for the engine. The 4A-GE valve springs seem like a step backwards. Generally speaking twincam valve springs are much softer than push rod valve springs because they don't have to push back on a long valve train. His drivetrain claims seem pretty bullshit too. Xanys got roughly that and hes smashing "bog" warners and K50s. I can't comment I'm an A man not a K man :P Report
December 9, 200619 yr comment_154346 Grouting the block normally refers to filling in the water jackets and just having the head water cooled so that you can run a bigger bore. taken from twincam.org - poster 'Trev084' You were willing to comment in the other forum Report
December 9, 200619 yr comment_154351 I've been through 4 K50s (in 6 years) on a stock motor, Hate to think how long they would last on a worked motor... Report
December 9, 200619 yr comment_154352 My 5K with glazed bores and single carby pulled 56rwKw. I have only ever broken 1 x K50 in 8 years of owning a corolla. That one g/box lasted 6 years with me before 2nd gear let fly. My 5K has since had a full rebuild and a pair of 40DHLA's put on it. Still no issues with the driveline breaking. I believe the life of your gearboxes is relative to how you drive, and how rough you are. That being said, I have 3 spare K50's down the back just in case. :P I'm keen to see a Dyno figure on the car in question though. I'm a bit skeptical of the figure myself. Report
December 9, 200619 yr comment_154355 fark that thing looks hot though, definatly a good pig spec... Report
December 9, 200619 yr comment_154356 You were willing to comment in the other forum OWNED!!! My 5K with glazed bores and single carby pulled 56rwKw. I have only ever broken 1 x K50 in 8 years of owning a corolla. That one g/box lasted 6 years with me before 2nd gear let fly. My 5K has since had a full rebuild and a pair of 40DHLA's put on it. Still no issues with the driveline breaking. I believe the life of your gearboxes is relative to how you drive, and how rough you are. Exactly right, I have smashed over 20 corolla diff's and almost 20 corolla gearboxes, and it has nothing to do with massive amounts of power, I had the SC on, but that still didn't have HUGE amounts of power, I did burnouts, and lots of them, and that is when they broke. Report
December 9, 200619 yr Author comment_154412 You were willing to comment in the other forum Yeah as they info i gave can be used on any engine, I don't know anything about k series motors. THIS: I can't comment I'm an A man not a K man REFERRED TO THIS: The 4A-GE valve springs seem like a step backwards. Generally speaking twincam valve springs are much softer than push rod valve springs because they don't have to push back on a long valve train. His drivetrain claims seem pretty bullshit too. Xanys got roughly that and hes smashing "bog" warners and K50s. Edited December 9, 200619 yr by Trev Report
