just wondering if anyone has had the same problemas i do!
i have a ae71 84 spirit corolla and a couple of days ago i noticed that when braking the lights on my speed and tacho come on but very faint, i havent had a look yet but wondering if anyone has had this problem before as i think its a short somewhere and i am going to have a look on the weekend at this problem.
just want some idea in what it is or if anyone has had this problem before me so i can work out whats going on, also when this happens my parkers only come on not my full headlight
if anyone has any ideas would be much appriciated.
thanks
yeah ok it must be a short somewhere in the brakes maybe i should replace the fuse for the brake and check the lights but any ideas whaty the direct problem could be??
just want places i can look so i can try and fix it asap
see what the brake light switch does: switches earth or +12v. if its earth then it could be the taillight is using it as an earth, if its +12v you probably have a short.
yeh sounds bout right... prob bad earth and the brakes lights are earthing through tail/park/dash lights.
check earths for rear lights first... theres a starting point!
yeah i have changed the bulb in the right tail light and problem has been fixed thanks for all your help!
  • 4 months later...
