How To Fit A W50 To A K Series Motor
how does it go for clearance in the tunnel? xmember requires new mounts?
  • 4 years later...
  • Replies 79
  • Views 224.3k
Hey Si,
Can you retain the K series Corolla spigot bearing?
I'm 99% sure you can, but can't confirm now cause I sold off all my w bits. Stu (tommys dad) could probably confirm as they're going to put a w50 in his 20.... using my old bell housing pictured.
I'll measure up for you later this arvo.
No worries Si, should be easy enough to confirm when I have everything on the ground. Just curious to see if someone knew.
Cheers Stu
