alloroC Posted June 14, 2007 Report Share Posted June 14, 2007 Hey. I'm getting sick of changing points in the 4ac and want to convert over to an electronic ignition system. what distributor fits in ? thanks Quote Link to comment Share on other sites More sharing options...
Trev Posted June 14, 2007 Report Share Posted June 14, 2007 Hey.I'm getting sick of changing points in the 4ac and want to convert over to an electronic ignition system. what distributor fits in ? thanks The AE82 4A-C came with a electronic ignition, I will double check today to see if i have a spare dizzy. Quote Link to comment Share on other sites More sharing options...
rollavan Posted June 15, 2007 Report Share Posted June 15, 2007 if the AE82 dizzy does fit, how does it wire up? as the module would need power Quote Link to comment Share on other sites More sharing options...
Trev Posted June 15, 2007 Report Share Posted June 15, 2007 (edited) Its just a 2 wire system: The coil is the same: Edited June 15, 2007 by Trev Quote Link to comment Share on other sites More sharing options...
smacko84 Posted June 16, 2007 Report Share Posted June 16, 2007 (edited) yeah i put a 4ac from an ae82 with electic ignition into my ke70 and it had the same wires. Just had to make up a lead to go from the coil i think from memory. I got an aftermarket coil for that engine as opposed to the normal one. Edited June 16, 2007 by smacko84 Quote Link to comment Share on other sites More sharing options...
Trev Posted June 16, 2007 Report Share Posted June 16, 2007 The AE82 4A-C came with a electronic ignition, I will double check today to see if i have a spare dizzy. Just had a look and the other dizzy i have is points so i can't help you. Quote Link to comment Share on other sites More sharing options...
alloroC Posted June 16, 2007 Author Report Share Posted June 16, 2007 Just had a look and the other dizzy i have is points so i can't help you. No worries, Picked up one from the wreckers from an AE82 along with the coil. It fitted perfectly. Made a huge improvement, so much more power. thanks for your help :) Quote Link to comment Share on other sites More sharing options...
Trev Posted June 16, 2007 Report Share Posted June 16, 2007 No worries, Picked up one from the wreckers from an AE82 along with the coil. It fitted perfectly. Made a huge improvement, so much more power. thanks for your help :) No worries mate. Quote Link to comment Share on other sites More sharing options...
tas_ae71 Posted July 16, 2007 Report Share Posted July 16, 2007 quick question with this, so you wack a ae82 dizzy in and you need a diffrent coil but all the wiring is the same correct? Quote Link to comment Share on other sites More sharing options...
tas_ae71 Posted July 21, 2007 Report Share Posted July 21, 2007 any love anyone..? so you need a ae82 4ac coil..? Quote Link to comment Share on other sites More sharing options...
Trev Posted July 21, 2007 Report Share Posted July 21, 2007 quick question with this, so you wack a ae82 dizzy in and you need a diffrent coil but all the wiring is the same correct? any love anyone..? so you need a ae82 4ac coil..? I will have a look tomorrow. Quote Link to comment Share on other sites More sharing options...
tas_ae71 Posted July 21, 2007 Report Share Posted July 21, 2007 cheers trev, i thought everyone was ignoring me :wink: Quote Link to comment Share on other sites More sharing options...
lowau Posted September 4, 2007 Report Share Posted September 4, 2007 Any news on where the std coil will work with the electric dizzy? The reason is that I just bought a new coil for the old points dizzy and don't really want to buy another one now to use with the AE82 electric dizzy. Quote Link to comment Share on other sites More sharing options...
KE30_KE35_KE55 Posted September 7, 2007 Report Share Posted September 7, 2007 Any news on where the std coil will work with the electric dizzy? The reason is that I just bought a new coil for the old points dizzy and don't really want to buy another one now to use with the AE82 electric dizzy. it may be a weaker spark than the point system. best off to use a high output 12 volt coil found on any 82-88 wrecked sigma, vh vk commodore, falcon or a ae82 here is the wiring diagram. Quote Link to comment Share on other sites More sharing options...
