Hey Guys,
Just wondering if anyone has changed door & boot locks on a ke55. just bought a set of Solex locks, came home and took the door trims off and there's no way i can reach the back of the locks. Do I have to remove the window or take the door apart ect.
Help would be appreciated.
Cheers
Chris.
Should just be a small metal clip (U shaped bit of flat steel with a angled bit to grab onto) holding the lock barrel agianst the outer door skin... stick ya hand up there, you'll find it.
Boot is the same.
Edited by 7shades
*disclaimer* Rollaclub in no way endorses child slavery.
I have a three year old who behaves like he's been engineering stuff for years. He's available by the hour.
I was going to suggest an angle grinder..........
If Rob's 3 year old is too expensive, my two year old knows how to whack things with a hammer........
  • 2 years later...
i just had a few questions on keys/ locks/ imobilisers for anyone who knows:
My ke55 never had a boot lock, and it doesnt have any keys, ive heard i can get a key made to suit the lock(/ignition) but if i got another boot lock, can that be altered to work with the new key? Or is the only way to have the one key work for everything to transplant door + ignition + boot locks from another car? Would a set of solex locks be the way to go? from a quick google i have heard both positive and negative things about them but if you have used them let me know your opinion.
Also i was just looking for any general comments or suggestions regarding the security of cars. eg. imobiliser? Alarm? What you are running and consider nescessary etc.
Thanks
Thanks
G`day mate, I worked in the motorcycle game for a number of years and it was commonplace to have to have keys made. The biggest problem is that you can`t get the ignition barrell out of the column without a key, so I would suggest taking a door lock out instead, pretty easy, and take it to any locksmith in your area. They will be able to make a set of keys for you within a day or so. They can quite easily change the innards of a boot lock for you also, giving one key fits all. From memory it didn`t cost too much either. Certainly cheaper than buying new secondhand stuff from a wrecker.
Good luck, Old Fella.
